Konica Minolta image issue
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta image issue
    Konica Minolta c658 prints black lines sometimes completely black prints.
    and sometimes working fine for the whole day.
    in service code history it shows c2557 couple of times happened.
    kindly advise. Some sample prints attached
    Thanks and Regards
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Konica Minolta image issue
    have you pulled the drum or anything looking for the stripes?
    upon visual inspection of drum and transfer belt you found what?
      • 23009
      We cannot guess which is the feed direction is on your prints. That makes a big difference. Have you looked up the C2557 error yet? I suspect that you have a seizing up black developing unit. =^..^=
      • tech51
        • 846
        Looking at the scans I would think your transfer belt is worn out and needs replacing and possibly the black drum as well.
        Some idea of the consumables life would be useful.
        • mearmi
          • Oct 2010
          • 350
          Drum and Belt are clean. Thing is it prints fine sometimes for the whole day.
          • mearmi
            • Oct 2010
            • 350
            Black dev and drums are new.
              • 23009
              I still do not know which direction that your images were printed. =^..^=
              • tsbservice
                Field tech
                • 8020
                I would open and clean PH unit and reseat ribbon cables.
                • mearmi
                  • Oct 2010
                  • 350
                  Both LEF and SEF
                  • mearmi
                    • Oct 2010
                    • 350
                    Originally posted by mearmi
                    Both LEF and SEF
                    First 2 pages SEF and 3rd page is LEF
                      • 14815
                      OEM or rebuilt?
                      • allan
                        RTFM!!
                        • 5462
                        Toner original?
                        Charge roller causing trouble?
                        Whatever
                        • mearmi
                          • Oct 2010
                          • 350
                          OEM or rebuilt?
                          OEM
                          • mearmi
                            • Oct 2010
                            • 350
                            Originally posted by allan
                            Toner original?
                            Allan
                            Original Toner and Replaced Black Dev and Drum
                            • 4Toon
                              • Mar 2023
                              • 112
                              If you can get the issues to come back maybe try a panic stop and see if the image is looking like that on the drum if not on the drum look at the belt image
                              Permanently banned from Konica SSD.
