C558 noise when printing
  • Chris Vibert
    • Oct 2013
    • 12
    [Misc] C558 noise when printing
    I have an issue with a Konica minolta C558 making a noise when printing only colour printouts but black prints is ok and quiet. Can you help?
  • barber782
    • Aug 2011
    • 281
    Re: C558 noise when printing
    What type of noise, buzzing, grinding, squealing?
    Sent from my VTR-L09 using Tapatalk
    • KMFLT3CH
      • May 2017
      • 226
      Never seen that on an 8 series but I have seen it a lot lately on i-series. Some internal components in the drums are not lubed well from the factory. I've seen brand new machines right after install with loud squealing drums.
      Remove the color drums one by one and turn them by hand using the knob on the rear - you'll hear the same squealing/high pitch scratching noise you do when running color jobs.
      • Chris Vibert
        • Oct 2013
        • 12
        Its a grinding noise.
        • barber782
          • Aug 2011
          • 281
          Iv had it a few times where one of the toner hopper motors was making a buzzing/grinding noise, replaced and all was good.
            • 22997
            Audio would help a lot. =^..^=
            • copyman
              Owner / Technician
              • Sep 2005
              • 4620
              Did you check the waste box chute? It can get packed with waste toner. Vacuum out
              • tmmdmmm
                • Apr 2021
                • 173
                I believe this is one motor that rotates regardless of B/W or Color. Makes more sense if its connected to Color Drums or Dev drive
                • allan
                  RTFM!!
                  • 5462
                  Any warning codes like P21? Could be transfer retraction but that will code out. If only on color it could be in the main drive but it will show on PQ.
                  Whatever
