C284e Print quality issue. Advise please.
  • chrisonline209
    • Sep 2023
    • 14
    #16
    Re: C284e Print quality issue. Advise please.
    Originally posted by Synthohol
    I don't understand. One is in English and one is not.
    These are 2 different documents.
    I'm just not seeing a true comparison since the 2 documents are different.
    I'll step back and let someone else help because I'm just not getting it.
    Thank you all for your help. You are all amazing. The problem was solved because of your advise. Initialized and Stabilized fixed the issue. Thank you, thank you, thank you!
    • Synthohol
      Certified Konica Expert
      • 5908
      #17
      Hope you ran all the gradation adjustments after!!
      • chrisonline209
        • Sep 2023
        • 14
        #18
        Will do the gradation
        • allan
          RTFM!!
          • 5462
          #19
          No real need to. Waste of time. Found that if you only do that in 90% of the cases its the best you will get.
          Initialize and stabilize will take it to factory and that is in most cases correct or good enough.
          Whatever
          • chrisonline209
            • Sep 2023
            • 14
            #20
            This is such a great forum. I recently met a technician in my area and I'm definitely going to share this forum with him. Thank you guys so much
            • copier tech
              • 8222
              #21
              Originally posted by chrisonline209
              Here is my test page.
              I can't see any issue with this print out.
              How about if you print a document from a USB pen, how does that look ?
