Konica C224e HDD issue! Freezing when installed
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I went to a C224e recently that the display would freeze after power up. You would see the usual 'Preparing User Box' etc with the control panel amber LED flashing. Then it would just freeze. No buttons would work on the control panel.
    I removed the HDD and the machine would get to the point where I could get into service mode and deselect the HDD as not installed, cycle the power and the machine would come ready - no freezing....
    So I went back into service mode, set the HDD to installed, powered down the printer, fit a new 320GB (although the one removed was 250GB) HDD, power back on and formatted the HDD. The printer would then freeze! I have then tried another 320gb HDD and a 250GB and the issue remains.
    Having had freezing issues before, I decided to replace the SSD PCB. Reflash firmware (M1) but it keeps freezing after power up.
    The machine works however with only the 2GB memory DIMM so scanning is an issue due to the size of documents etc. Also, I am unable to access the web interface despite doing a clear all data, making sure PSWC is set to on etc.
    I have also run a self diagnostics test and all items pass.....
    I am currently in the process of the 'Detail Check' of the memory in state confirmation of service mode. It is currently getting to 90% then starting over and over.. Maybe I miss it getting to 100%, I will keep watching it......
    I have a memory dimm on order so will try that and see where I am but if not, I can only assume the MFP board is next?
    Has anyone else experienced this?
    TIA
  • jonbonse
    • Jun 2009
    • 737
    Re: Konica C224e HDD issue! Freezing when installed
    Originally posted by jonbonse
    Hi all
    TIA
    Update: Definately gets to 90% then back to 0% when doing the 'Detail Check' of the Memory....
    • femaster
      • May 2011
      • 1500
      Hi all
      TIA
      As far as I know the detail check just keeps checking over and over again indefinitely. I've never seen the detail check "finish", so I assume that is the way it should operate.
      • tsbservice
        Field tech
        • 8007
        I had something similar which never gets fully resolved due customer's happy with workaround and not let me change parts . What if you push 3 hard keys under control panel?
        • copier tech
          • 8142
          You might find fitting a NEW HDD will resolve the issue. And it's always worth updating the firmware & function version.
          • jonbonse
            • Jun 2009
            • 737
            Thanks but already tried 3 drives and redone firmware/function version to the latest which I believe is M1 function v7...
            • jonbonse
              • Jun 2009
              • 737
              Nothing happens 😕 still frozen...
              • Synthohol
                Certified Konica Expert
                • 5822
                Just to ask, have you replaced the sata cable as well?
                Thought it would be worth a shot
                • jonbonse
                  • Jun 2009
                  • 737
                  No but definitely worth a go!
                  • Gift
                    • Mar 2011
                    • 2459
                    Even though this is not a typical symptome for a dying battery - did you check the voltage of the MFP batttery?
                    Guess it has nothing to do with it though - you might have a bad S-ATA controller on the MFP board. So perhaps you can get your hands on a donator to swap the MFP board?
                    (check the procedure first)
                    • jonbonse
                      • Jun 2009
                      • 737
                      So i fit exact same memory dimm but the printer did not show any lights etc so put the old dimm back in.
                      Also tried a new sata cable no different...
                      Weird as the hdd is recognised and lets me format it but after a power cycle, comes ready with the usual 'Animation guide missing' then freezes..
                      Looks like its going to be a machine stripped for spares as a new MFP board outways the cost of the machine being obsolete!
                      • Synthohol
                        • 5822
                        sent you SSD fw v6.03. hope it helps.
                        • jonbonse
                          • Jun 2009
                          • 737
                          Thanks mate but already on 6.03
                          • Synthohol
                            • 5822
                            have you tried a data initialization or formatting the ssd? not the hdd, the ssd?
                            • rrrohan
                              • Sep 2011
                              • 1977
                              6.05 is the latest version https://1drv.ms/f/s!Ah_79nptMOdwgZ0L...__tpQ?e=LffneV
