C2060l Jam relase knob rotating freely
  • Toxic
    • 696
    Hey guys, today i had customer complaining jam relase knob rotating freely without rotating fuser belt and fuser rollers.
    Besides that fuser works ok during printing, it just can not be turned by hand if paper jam in fuser.
    I had that problem years ago on C1060l and i can not find now in my documentation what specific gear was culprit in that time.
    Customer is not really close to me and i should drive few hours just to see what gear i need to order so if somebody had this issue and know which gear is culprit in this case, that would be helpful.
    If i remember good, that problematic gear is not scheduled for replacement in periodic maintenance.
  • allan
    RTFM!!
    • 5463
    Re: C2060l Jam relase knob rotating freely
    Sounds like a one-way bearing that is gone, slipping or installed backwards. Could be in the hub of a gear. On the b/w machines the one way bearing is in the knob itself.
    Whatever
    • wjurls
      • Feb 2017
      • 492
      There is a tabbed gear on one of the fuser belt rollers. The tab shears off. Very common issue. It only effect the jam release knob.
      Once it breaks it will likely need all three common to fail gears in the fuser.
      1.A50U752700 Fusing Gear/1 38T Lower roller gear
      2.
      A50U739811 Fuser Belt Drive Gear /Front 38T <----- This one is your bogey
      3.
      A50U725001 Fuser Belt Drive Gear /Upper 38T
        • 22973
        I've changed quite a lot of those gears on the front of the foam roller. When you are changing the foam roller or have it apart, it is possible to install the foam roller backwards. The gear at the rear is slightly wider than the gear at the front, and they are not interchangeable (unless you do some Dremel work, and I've had to when I ordered the wrong one).
        So just be aware, when it's apart the narrower black gear is towards the front, wider white gear towards the rear. The consequence is that the foam roller bearings fall out of the frame, and you lose fuser pressure at front, or rear, or both. And the wider gear tries to rub it's way through the metal frame. It will after long enough.
        The gears at the rear will eventually show wear when you near 2M. =^..^=
        • wjurls
          • Feb 2017
          • 492
          All too familiar a scene
          • zayonc
            • Jan 2022
            • 48
            Re: C2060l Jam relase ручка вращается свободно
            The arrow on the green handle points in the wrong direction so users break the gear. On the first c1060 this arrow pointed in both directions, then information appeared that it could only be rotated in one direction. On the c2060, the arrow was already directed only in one direction, but in the wrong direction. and this continues to this day.
            • Toxic
              • 696
              Thanks guys, now i remember those gears and i ordered it.
              @zayonc
              Regarding rotating knob in both directions, i remember from older series C6501, c6000,... you can rotate knob in one direction to eject jamed paper and in other knob rotating direction fusing doing retraction operation of fuser belt and lower roller.
              That is not the case on C1060l, C2060l if i understand you good?
              I rotating that knob many times but my brain can not recall how it works but i think it is rotating in both ways.
              • wjurls
                • Feb 2017
                • 492
                @zayonc
                6500/6000 series used 3 one way gears to allow fuser drive when the motor spins one direction, and fusing belt pressure adjustment in the reverse direction. It was a terrible design and was ditched for the 1060 series and up.
                The fuser knob on the C1060 is connected to the belt roller through fixed gears. You can technically turn it both directions but it will fight you in reverse.
