MINOLTA C224e (restart problem)
  • M1963
    • Jun 2017
    • 67
    greeting,
    I'm trying to get rid of the C224e that occurs every 3-4 seconds. restart.
    I tried to upgrade the SSD firmware (A5C10Y0-F000-G00-A9-04--SSD-FW-Ver6.03m) but it fails to load.
    I will stick to the topic from 2019.
    https://www.copytechnet.com/forums/k...irmware-4.html
    please if someone can send me the firmware C224e_C284e_C364e_A5C10Y0-F000-G00-G9.exe so I can try it maybe I will succeed.
    thank you in advance
  • Woxner
    • Jul 2011
    • 852
    Re: MINOLTA C224e (restart problem)
    If its rebooting every 3 4 seconds firmware will not help yet. You will need new ssd bd. Because of the quick reboot it does not give time to load boot file
    • M1963
      • Jun 2017
      • 67
      looks like it won't.
      thanks for your opinion
      • Albonline
        • Sep 2008
        • 1153
        did you try with the big side door open?
        • M1963
          • Jun 2017
          • 67
          I tried all variants
          • Albonline
            • Sep 2008
            • 1153
            remove ssd and try unplug hhd. if it does not reboot you found the cause. with ssd removed you should only see the op panel startup screen.
            • ronny2502
              • Mar 2020
              • 80
              Originally posted by Albonline
              remove ssd and try unplug hhd. ...
              Hello,
              thats a good idea!
              In addition:
              I'm not 100% sure, but I think I remember that you also have to DISABLE HDD and reboot machine in case HDD is disconnected/removed. Else machine will run into an error in any case.
              Regards,
              Ro
              • M1963
                • Jun 2017
                • 67
                Greeting,
                I just installed a new SSD but it asks for SSD-FW-Ver 6.06m which I don't have, so please if someone could send it to me to solve the problem.
                thank you.
                • copier tech
                  • 8195
                  Greeting,
                  thank you.
                  We are happy to supply this for you if it's still required.
                  Please contact us at either web link below.
                  โ€‹
                  • tsbservice
                    Field tech
                    • 8035
                    Greeting,
                    thank you.
                    New SSD would require a firmware update. Did you install it?
                    • M1963
                      • Jun 2017
                      • 67
                      yes you are right, it is solved with the upgrade with the new firmware.
                      Thank you for your support.
