c454e - streaks where Y toner missing
  • frood
    • Sep 2022
    • 17
    Hi all,
    I replaced a lot of worn parts on a high milage c454e I own for small business use.
    Due to age and CLEAR physical damage, I have replaced thus far already:
    CMYK Drums
    Image Transfer Belt (dented and scratched badly)
    Quality is vastly improved, and I've verified the corona wires are clean an the Y drum unit scraper looks fine and has not clumps on it.
    Yet, the (missing yellow) lines where yellow toner is either not getting placed or being scraped off before placement persist.
    Any advice appreciated.
    Since I'm generally not printing full color pages, it's rarely an issue. But ... I'd REALLY like to fix it ... lol.
  • femaster
    • May 2011
    • 1492
    Re: c454e - streaks where Y toner missing
    Going to need samples in order attempt to figure this one out.
    Based on your description, it sounds like this machine was abused pretty badly. Did you acquire it this way, or any idea how it got damaged like it did? It's possible the problem could lie in the development unit for yellow. Have you verified you have a nice even layer on the mag roller for yellow? Perhaps there is something blocking part of the laser glass for the yellow. If machine was jarred, maybe the magnet in the mag roller of the yellow development unit is broken. It's a fairly rare thing to happen, but not unheard of.
      • 23006
      I haven't anything to add to that. =^..^=
      • frood
        • Sep 2022
        • 17
        Image didn't attach to OP for some reason.
        Abuse - Let's call it neglect. Non-consumable parts are in great shape, it just had all consumable life notifications off. Drums were just run without ever changing as was the transfer belt. Original yellow drum had caked toner chunks all through it so it was first to be replaced, then did others as well after observing they were well past useful life.
        • tsbservice
          Field tech
          • 8003
          As it was said, take out yellow drum then developer unit and closely observe areas where strikes are against mag roller brush. If coating is even and no missing zones clean thoroughly PH unit (laser). You may need to remove it from machine. While laser is removed it's probably good idea to open it and clean poly motor mirrors, be very careful while doing that.
          Also don't forget to click on thanks when your problem is solved but even better contribute to this site maintenance and administration
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5814
            there are gradation and halftone test patterns to output each color.
            this will help greatly in diagnosing quality issues.
            this should be a requirement to post both sets of test prints.
            otherwise this guessing is like pulling teeth from a clam.
            these copiers have these test patterns built in to help diagnose issues but almost nobody uses or checks them first.
            but at first glance the issues seems to be in the DV units if the drums were really replaced with real new units.
            are they new drums or just the cylinders? new ones have new coronas.
            could tell better with real test patterns please.
            • frood
              • Sep 2022
              • 17
              FFS. I'd cleaned the laser glass with the flippin' tool three times.
              Just did it ONE more time and kind of leveraged it "up" to put a little more pressure on the glass (in case it was stuck) and ... lines gone.
              Thanks all.
              Here are a few samples. The only thing I think could look better would be the black; it's kind of line-y. But, actual demo print comes out nice.
              (note on cyan sample; the dark rectangles are from a print underneath, they're not in the test print)
              If you think there's something obvious I should do, welcome to ideas. But I'm sorted for now for the streaking issue.
              20231021_181049 (2).jpg (note, dark rectangles are from a print behind, not flaws)
              • femaster
                • May 2011
                • 1492
                Based on those last samples, my first guess would have been that the black drum was getting weak, or the corona wires and/or grid needed a good cleaning. Since you said you already replaced all the drums, I have to assume that is not the problem then, and it is probably the case that there is still some stuff left on the laser glass of the black. Or perhaps the DR blade in the dev unit has some junk stuck in it and is creating those light streaks on the output.
                In addition, if you haven't run it already, I'd run gradation adjustments in order to bring things back into alignment since there are so many new parts. It may even look better after doing that.
                • mascan42
                  • 484
                  I would consider pulling out the print head and examining the glass. I've seen it get scratches that can cause toner buildup to be EXTREMELY difficult to clean.
