BizHub C224e
  • rrrohan
    • Sep 2011
    • 1977
    #16
    Re: BizHub C224e
    Originally posted by copyman
    Thanks for the reply, Also does it on 2nd side when duplexing.
    so theoretically we have rules out the DS Board and the CCD
    im guess the MFPB. i was always told never to switch MFBP from its original copier so i have never tried it so dont have any XP with MFPB swap issues
    • copyman
      Owner / Technician
      • Sep 2005
      • 4719
      #17
      Re: BizHub C224e
      I've swapped the MFPB from one machine to another many times without issues. Important to "cleanse" the board with firmware. Same thing Hytec dealer services does if you buy a repaired MFPB from them.
      • Albonline
        • Sep 2008
        • 1151
        #18
        Re: BizHub C224e
        Originally posted by 4Toon
        yes check to see if the duplex side is doing the same thing. Also check LED exposure to make sure its lighting up, seems to me its not getting light to the page to aluminate your copy and so its getting you a nice purple. LED exposure is a ribbon cable LU201. You can do a non image area test in service mode would show you if that is turning on properly. try doing a memory check too and see if there is any issues there
        not all adfs for this model have cis's.
        • Albonline
          • Sep 2008
          • 1151
          #19
          Re: BizHub C224e
          cleanse used board first. use original ssd , a failure code a first boot will display a code and should ask if you want to restore system, answer yes.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4719
            #20
            Re: BizHub C224e
            This C224e does have the dual scan DF-701
            • tsbservice
              Field tech
              • 8020
              #21
              Re: BizHub C224e
              Do you have DF selected in service mode as dual scan?
              • Albonline
                • Sep 2008
                • 1151
                #22
                Re: BizHub C224e
                he must, failure code would happen otherwise.
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  Re: BizHub C224e
                  Really appreciate your posts. Thanks for coming to help.
