BH-C-3110 needs replacement.....
  • Hansoon
    • Sep 2007
    • 3380
    Customer is not satisfied with her BH-C-3110 since copies from the platen all have a little greyish shade around the originals smaller than A4 size. Cleaned the usual such as the optics. No improvement. I do not like to fiddle around with mirrors etc., so “better” have another of the pre-owned A4-color machines from Konica Minolta.
    Is there anyone of the following generations you could more or less advise? I have seen here in the panel some gruesome reports about those next generation A4-Color gems from Konica Minolta. Any advice please?
    Hans
  • tsbservice
    Field tech
    • 8007
    Re: BH-C-3110 needs replacement.....
    Honestly I dislike all KM A4 color products but from my experience C3350/1 can run pretty much from PM to PM without much troubles. Stay away from those A4 color i series or you're going to lose customers.
    • Synthohol
      Certified Konica Expert
      • 5820
      [Quality] - [Bkgd. Removal] Adjust the background density of an original with the colored background such as newspaper or an original made from recycled paper.
      this helps. you can set as default or a shortcut but the setting should remove the shadow/halo around small originals during copy or scan.
      good luck.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4679
        Agree with tsb to stay away from kon min "color" small machines. Their small A4 B&W models are made by Lexmark, etc. and are ok but their own design color models are built cheap. Light fuse, get away
        • copier tech
          • 8142
          If you can find low millage Bizhub C3351 these are pretty reliable.
