Web Interface not showing after enabling SSL settings
  • CopierNerd
    • Feb 2015
    • 207
    Hi,
    Hope all of you will be fine and enjoying good healthy life!
    Model : bizhub c364
    Firmware Version: A1610Y0-F000-GD9-72
    Problem : We want to upgrade it to the latest version. I dont know which one is the latest version that will work with this one. I have tried 8 different c364 firmwares and it gives error after upgrading "this is invalid external memory" So have to install the same firmware back.
    The problem is, this firmware is not compatible with the latest SSL settings of the web browser. Machine doesnt show web interface after enabling SSL > Admin & User Mode in Security Settings. Device certificate creation.
    I think the SSL settings of the machine is not compatible with the browser settings. Old internet explorer works but the chrome, Edge, Firefox doesnt show web connection.
    If anyone can share the latest firmware that will work with the version mentioned that will be quite helpful and much appreciating.
    If there is any other solution to fix it without upgrading firmware then please.......... SHARE!
    Many Thanks....!!!
  • copier tech
    • 8164
    Re: Web Interface not showing after enabling SSL settings
    Originally posted by CopierNerd
    Hi,
    Model : bizhub c364
    Many Thanks....!!!
    You could try the 'version up firmware' this gives the C364 series an upgrade to give many of the C364'e' settings etc.
    Version Up Firmware Technical Information Rev4.pdf
    • CopierNerd
      • Feb 2015
      • 207
      [ATTACH]60446[/ATTACH]
      Thank you for reply.
      This upgrading can be fatal? Difficult to recover. I also need Web browser function.
      • copier tech
        • 8164
        No, i've never had any issues doing this upgrade. You can roll it back after if you no longer need it.
        • ronny2502
          • Mar 2020
          • 79
          Hello,
          this error message "invalid external Memory" can occur if there is a problem with the service USB port. > You can check the sensor behind the service usb port.
          It is right above the HDD.
          Worst case: MFPB could be faulty.
          Good luck,
          Ro
          • CopierNerd
            • Feb 2015
            • 207
            Originally posted by ronny2502
            Hello,
            [ATTACH=CONFIG]60449[/ATTACH]
            Good luck,
            Ro
            Thats quite right!
            But the problem is only 1 firmware can be installed and it works. If you try other firmware it gives NG to MFP controller.
            • CopierNerd
              • Feb 2015
              • 207
              Can you share that firmware?
              • CopierNerd
                • Feb 2015
                • 207
                I dont need firmware. I am looking for solution. How to change/Upgrade SSL settings of machine?
                • tsbservice
                  Field tech
                  • 8019
                  Normally it's under Security settings - PKI - SSL/TLS settings.
                    • 14754
                    Are you using https when trying to log into web interface?
                    • CopierNerd
                      • Feb 2015
                      • 207
                      Yes, thats right. But web interface gets inaccessible after enabling SSL in Certificate settings. Admin/User mode.
                      • CopierNerd
                        • Feb 2015
                        • 207
                        I have tried both HTTP / HTTPS. Windows 7 has internet explorer. Web interface shows using internet explorer. It doesnt work on Chrome, Edge, Mozilla etc.
                        • tsbservice
                          Field tech
                          • 8019
                          Modern browsers deprecate insecure TLS/SSL versions.
                          You can try to enable them(at your own risk) see link:
                          How to Turn Off SSL 3.0 and TLS 1.0 in Your Internet Browser - SSL.com
                          • kingarthur
                            • 1364
                            give the device a different IP and then see if it works - in our showroom, after setting up SSL, there are some IP addresses that I can't access the web interface - no idea why
                            • CopierNerd
                              • Feb 2015
                              • 207
                              It works with the old browsers only not working with the latest. After enabling SSL on machine it disappears..... thats the problem
