J93-10 Duplex Paper Jamming bizhub c454e
  • Jinn
    • May 2023
    • 134
    Single side printing is working fine. Duplex printing paper jams at reversal section. It goes to the duplex exit and then solenoid pulls the gate when it's reversing it jams there entering the duplex Gray rollers. Machine is indicating jam at 14 number but paper is not activating that sensor. EXIT SECTION replaced. Reversal section replaced but still paper is jamming at the same location.
    • 23009
    Re: J93-10 Duplex Paper Jamming bizhub c454e
    On similar Minolta style engines I've seen:
    *rusting or damaged duplex clutch
    *worn LCF rollers
    *dirty ADU rollers
    *duplex flag is worn down
    *wire harness to the lower duplex sensor is mis-routed over the flag, preventing the flag from moving smoothly.
