Bizhub c224e- pm parts list
  • RandyW
    • Jan 2013
    • 213
    Looking through the service manual- is there way to print out the counter list for pm parts?
    I see LIST OUTPUT but that puts it on a USB drive?
    Trying to work out what PM parts maybe needed.
    thanks
  • Ziggy
    • Feb 2018
    • 687
    Re: Bizhub c224e- pm parts list
    thanks
    Not sure on this model but on the newer models you can set switch 227 to hex 00 and then you will have the check consumable button on the user menu screen
    • tsbservice
      Field tech
      • 7934
      thanks
      Go to list print and select MML(machine management list) print it instead of saving to USB there you have all needed.
      Another way is what Markks said under utility you should see consumables part list and check it.
      • Synthohol
        Certified Konica Expert
        • 5750
        here ya go.
