Error code C-E301 on C454e
  • Gama
    • Nov 2023
    • 8
    Dear all I get above error code in my KM machine,
    I Tried HDD format
    reset but didn't able to fix the issue yet
    Current FW ASC10Y0-1E00-G00-04
    Can anyone advice me about issue and how to sort it out ?
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: Error code C-E301 on C454e
    ck your PMs, it can still be a bad hdd.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4654
      Do a "logical" format on the hard drive & update firmware
      • Copier repairman
        • Aug 2019
        • 86
        [QUOTE=Gama;2535007]KM 시스템에서 위의 오류 코드가 발생하여
        HDD 포맷 재설정을 시도했지만
        아직 문제를 해결할 수 없었습니다.
        현재 FW ASC10Y0-1E00-G00-04
        문제 및 문제에 대해 조언해 줄 수 있는 사람이 있습니까? 어떻게 정리하나요?
        감사합니다[/인용문]
        The back-up battery needs to be checked for discharge.
        • Gama
          • Nov 2023
          • 8
          [QUOTE=Copier repairman;2535341]
          HDD 포맷 재설정을 시도했지만
          아직 문제를 해결할 수 없었습니다.
          감사합니다[/인용문]
          I will check voltages tomorrow and update
          • Gama
            • Nov 2023
            • 8
            I did HDD physical format and Logical format
            also run self diagnosis yet it is still there
            I have FW_A5C10Y0-F000-GDU-M1 Firmware which i got from online friend
            Will it okay to update current machine ?
            • Gama
              • Nov 2023
              • 8
              [QUOTE=Synthohol;2535064]ck your PMs, it can still be a bad hdd.[/QUOTE
              Thank you for the quick response How can I check HDD for bad ? Can I check HDD by connecting to PC ?
              I have FW_A5C10Y0-F000-GDU-M1 firmware will it okay to update with that as well ?
              • Synthohol
                • 5808
                yes ok to update just find out the function version.
                as far as a PC you can use disk manager and delete all the partitions and create 1 partition but DO NOT FORMAT IT!!!!!
                put it back in the copier and see if it boots up and we can go from there.
                • Gama
                  • Nov 2023
                  • 8
                  Please can anybody advice me regarding what function level is M1 firmware ? quick guide on how to install G20-M1 FW will much appreciate as I'm new to firmware install
                  Thanks All
