PC-210 (BH-C-284e) no cassette lift
  • Hansoon
    • Sep 2007
    • 3389
    Have one PC-210 (BH-C-284e) where the lift-up of the both cassettes is not working, resulting in a C0206 and C0208. Are there any ICP's known on the board of the PC-210 possibly causing this? 24VDC is coming from the machine to the board.
    Hans
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: PC-210 (BH-C-284e) no cassette lift
    see if they lift if you push\hold them in.
    try a trouble reset, reseat the cables from machine to pf cab.
    check the couplers
    do you hear the motors turn at least?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4721
      + 2 on what Synthohol posted.
      Just to confirm does the machine does recognize both tray 3 & 4 on display?
      Had this been working and just stopped? If not then I would look for bent pin, etc on connector for PC210 to copier.
      • Hansoon
        • Sep 2007
        • 3389
        Not sure if it was working before, it came from a wholesaler.
        Lift-up motors are not running but the PC-210 cassette shows present in the display as well as its trays. After closing one of the two lower trays and then after a short while, there's a clack coming from the MFP's mainboard and the machine codes out.
        I will get from the storage another PC-210 unit and cross-check if the problem lays in the machine itself or the extra cassette deck.
        Hans
        • allan
          RTFM!!
          • 5462
          Hans
          I would also guess that its not getting supply voltage. Do the cross check and let us know. Will need to spend time on the wiring diagrams.
          Whatever
