Operation a success! Stone removed!!!!
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    Not my stone....but a C454e toner hopper stone. The hopper just couldn't pass stone because it was 1/2" and hard as a rock (see attached pic). So surgery was necessary
    Here's how it went down. Get a call that prints were missing Cyan. So of course I figure the usual suspect of cyan developer dumping because of overlife drum. When i got there cyan level history was 0%. After replacing cyan drum & dev unit level history was good at 6.5% so out the door I went. Few days later they call back reporting trouble code C2551 "cyan trouble". Went back and machine would not add cyan toner and level history back at 0%, vac'd out the hopper unit and when I split hopper there was the stone and reason it wasn't adding toner. I've never seen anything like it unless a copier was in extremely hot conditions and low volume. Weird because this customer is not low volume and only uses genuine Kon/Min toners. There's a first for everything.......
  • aberock
    • May 2022
    • 124
    Re: Operation a success! Stone removed!!!!
    some times genuine KM toner come with a lot of special code like " S " , " A "
    TN321AC
    TN712S
    there must be some thing with the code
      • 23008
      Agreed. The only time you usually see rocks like that is when the machine's internal temperature is too hot. Did you notice that that particular rock looks like a cube? It's almost as if that rock never went through the grinder in manufacturing.
      Thanks for sharing. =^..^=
      • mojorolla
        The Wolf
        • 2609
        That thing is huge! You should add geologist to your resume after that call.
        • wjurls
          • Feb 2017
          • 496
          Just went through this with a C458 in Vegas. 2 trips and a developing unit, then just developer later, I finally found and extracted the stone from the toner conveyance system.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4701
            I know the OEM's keep lowering the fuser temp & melting point of toner to save energy but I hope these big chunks of toner isn't happening because of it. I've never seen any of these weird toner issues until the toner shortage awhile back.
