Problem on konica minolta c554 fuser
  • enricocopyline
    • Jun 2018
    • 122
    I have a problem on a Konica Minolta C554 in the first print and ONLY in the first one does the problem as in the photo.
    I tried to replace the fuser oil roller but I didn't solve the problem, nor did I increase the fuser temperature by 5 degrees.
    Do I have to replace the entire fuser or is there some other way to fix it?
  • copier tech
    • 8142
    Re: Problem on konica minolta c554 fuser
    [ATTACH=CONFIG]60878[/ATTACH][ATTACH=CONFIG]60879[/ATTACH]
    Fit a new fuser unit!
    • Todd Glenn
      • May 2021
      • 22
      Turn the temperature up 10 degrees, or try mode 3 or 4 in service mode SYSTEM 1, WARMUP.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4679
        Up temp to +10 and turn off sleep in admin mode.
        These fusers are rated at 1.2 million but usually last closer to 500K. High volume users may get 1 million but not lower volume users. Of course also depends on what end user is running like thick stock, duplexing, etc.
