1250p printing pages bot half and completely dark.
  • nullskull
    Learning
    • Aug 2023
    • 396
    Hey so this 1250p I was using all the sudden started to print with half the page just as seen in the first picture. After going into admin mode I ran a couple developer and auto density adjust things. (Don't remember the exact ones but will check if it's important. Probably dumb but it did work before for certain similar situation.) The machine was serviced/cleaned recently so I don't know if it has something to do with that. test prints within the admin mode did not seem to show anything but on rebooting the machine the prints are normal again. Anyone know what happened?
  • wjurls
    • Feb 2017
    • 494
    Re: 1250p printing pages bot half and completely dark.
    Looks like you may have killed the LPH while cleaning it. It should only be dry wiped with a clean microfiber rag.
      • 22997
      I think I have an image of what a failing LED printhead looks like. You get images repeating front to back on your LEF prints, which would be mechanically impossible to do. The LED printhead overheats. Often by the time you arrive for your service call the printhead has cooled down, and works fine upon arrival:
      LED test sample1.JPGLED test sample2.JPG =^..^=
        • 22997
        I've always used a blower brush or towel with alcohol to clean the LED printhead. I believe that the vacuum could permanently damage it. =^..^=
        • wjurls
          • Feb 2017
          • 494
          Vacuum for sure would be kiss of death. I also killed one using a moist Q-tip. Had results similar to what OP posted.
          • nullskull
            Learning
            • Aug 2023
            • 396
            Ok since it is working fine now would you say to be safe I should order a replacement? And if so do you know the part number or name of the part? thanks
            • wjurls
              • Feb 2017
              • 494
              Not yet, they are stupid expensive. You may have dodged a bullet. If you do end up needing one, let me know. I have some used ones.
              A4EUR75300 LPH Assembly
              • nullskull
                Learning
                • Aug 2023
                • 396
                woah you're right. 1000 just for that
                  • 22997
                  I'm as optimistic as the next guy ... but chances are, you'll be ordering it. The symptoms will happen more often and more often, until you cannot pretend anymore. =^..^=
                  • nullskull
                    Learning
                    • Aug 2023
                    • 396
                    what causes the part to break anyway? just overuse or something else?
                      • 22997
                      I believe the electronics in the printhead overheat. If allowed to cool it often resets, and works for another while. =^..^=
                      • zayonc
                        • Jan 2022
                        • 48
                        Need to reconnect both ends of the LPC cable. Usually helps
                        • techsxge
                          • Jan 2022
                          • 660
                          [ATTACH=CONFIG]60912[/ATTACH][ATTACH=CONFIG]60911[/ATTACH] =^..^=
                          i have to say that menu looks good
