6136 P and PF710
  • emujo2
    • Mar 2017
    • 1579
    [Misc] 6136 P and PF710
    we are swapping PF 707's with PF710s on 3 6136Ps. At power on each PF 710 throws a C0456 communication error. Tech has updated F/W but no change, Other than S/N entry, there are no config steps in the install guide and these should work W/O a hitch. Any thoughts?
    Just a quick edit..we are moving from a PF 709 to a PF 710. The KM site does not have a install guide listed for the PF 709 so I can't tell if there was some softswitch that is no longer needed. Fun stuff.
    • 23009
    Re: 6136 P and PF710
    I seem to recall having to install a media sensor option when installing some of these paper decks. Check on that. =^..^=
    • Afanasy
      • Aug 2023
      • 26
      Hi, there are different numbers of connectors. Maybe it will help:
      • emujo2
        • Mar 2017
        • 1579
        The issue turned out to be the 710 now has 2 material numbers, A9JXWY1 and 2..WY2 will not work on the 6136..The rep ordered the PFUs (WY2) based on the previous 7136 we had just installed.
        • Ziggy
          • Feb 2018
          • 784
          KM makes changes in the accessories so you cant use older accessories on newer machines . Attaching chart
          Product code is first four of serial number area code is the next three digits of serial number. I would look at this before attempting to hook that booklet maker to another machine. It was a .xls file I converted to .pdf so its a little difficult read but can be done
          • bizhubPROricohPRO
            • May 2019
            • 5
            PF 707 does not work with 6120/6136. It looks the same, but these are different models from the PF 710.
