KM c224e - won't print, error code C-D353
  • zodiaco
    • Feb 2021
    • 27
    Dear all, my KM c224e (150000 pages) stopped working quite suddenly. It wont accept any printing jobs, so I turned it off and back on from the main switch. Now it won't boot, it gets stuck at a two bar screen forever, then eventually would spit error code C-D353. I am stuck here. What can I do?
    Thank you! Darius
  • zodiaco
    • Feb 2021
    • 27
    Re: KM c224e - won't print, error code C-D353
    Update: In the meantime I have reset the "trouble code" twice, but to no avail. And now the printer stopped booting up altogether and is stuck at a black screen with two gray "bars".
    I appreciate any assistance.
    Thank you! Darius
    • Black Cloud
      • 162
      Sounds like the NVRAM has failed. If not the MFP board needs replacement. 90% of the time it's the NVRAM. Common issue with these units.
      Net+ PDI+ @Remote
      • zodiaco
        • Feb 2021
        • 27
        Thank you - what can I do? replace the NVRAM? Who sells it?
        Thank you!
        • copier tech
          • 8144
          Thank you! Darius
          Could be HDD failing or the SSD.
          You could also try a firmware update or the NVRam reset tool.
          • aberock
            • May 2022
            • 124
            Thank you! Darius
            Change NVRAM and reload firmware
            • zodiaco
              • Feb 2021
              • 27
              Is this something I can do? I know how to change the NVRAM SODIMM but how am I going about the firmware and possibly NVRAM reset? Thank you!
              Darius
              • copier tech
                • 8144
                Darius
                I would try the NVRam reset tool before replacing any parts,
                • zodiaco
                  • Feb 2021
                  • 27
                  Where do I get that from?
                  Also, after 12h pause the copier boots up but asks for "serial number" (serial number must be entered. contact your service representative)
                  THANK YOU
                  • Synthohol
                    Certified Konica Expert
                    • 5824
                    did you enter the serial number?
                    • tsbservice
                      Field tech
                      • 8011
                      First you will need to replace backup battery on MFP board.
                      • zodiaco
                        • Feb 2021
                        • 27
                        How? I can't get to the keypad display.
                        • zodiaco
                          • Feb 2021
                          • 27
                          UPDATE: had a tech come out and look at the machine. His verdict was that it needs a new main board but that's impossible to replace because KM wouldn't release the license code needed to activate the new board due to machine being >5 years old. So he offered me a new machine.
                          He said he reset the NVRAM, got the machine back to live for a few seconds but it would "lock up" immediately, which is a sign for main board failure.
                          Is there anything I can do at this point? I bought the machine in 2017 and it has 135k pages on the clock.
                          I appreciate all of your help.
                          D
                          • copier tech
                            • 8144
                            D
                            I would purchase a cheap used C224e & use the MDP board from that.
                            • zodiaco
                              • Feb 2021
                              • 27
                              I don;t know where to get a cheap 224, but I see MDPs for sale on ebay? however, the KM tech said I cannot replace the MFP? Can you please help?
                              Thank you!
