Konica 654 error code D012
  • dbeyma
    • 21
    [Error Code] Konica 654 error code D012
    Are there any independent Konica techs in the Detroit/Southeastern Michigan area that want to do a service call on my Konica c654 .
    Apparently it was wiped by the dealer and now I have a d012 code.
    Not sure how to load/update firmware. Thanks
  • Synthohol
    Certified Konica Expert
    • 5897
    Re: Konica 654 error code D012
    first things first, remove the back cover and make sure there IS a HDD mounted.
    you can go into service mode and disable the hdd and see if the code goes away.
    as far as firmware or movie data i think i can help you there, you are a contributor
    let me know if there is a working hdd mounted and we can go from there
    [edit]sent you a PM[/edit]
    • dbeyma
      • 21
      Yes, it has the HDD
      • Synthohol
        • 5897
        my suggestion is to disconnect hdd and cable go into service mode and disable the hdd and reboot, see if the code goes away.
        if it does you can either replace the HDD or try to format it (logical, never physical) and i think i sent you the link for movie data too.
        • Albonline
          • Sep 2008
          • 1153
          depending how it was wiped, you may only need to do a logical format on the drive. looks by the code to have been formatted physically.
          • copier tech
            • 8202
            • Code: CD012
            • Description:Causes:Hard disk
            • Remedy:1 Logically format the hard disk and then upgrade the firmware. 2 Replace the hard disk.
            • dbeyma
              • 21
