bizhub c-3320-3350i c2558 and similar
  • avio2
    • Jul 2010
    • 150
    i hate this model( and service tech site ), replace 2 new iu k , agg fw at last version and forced fast stiiring
    but work 2 week ang again error tcr k% at 10%
    now have another shit whit 2554 tcr m 10%
    anyone have a definetly solution???????????????
  • aberock
    • May 2022
    • 124
    Re: bizhub c-3320-3350i c2558 and similar
    check your toner hopper unit ?
    what's the counter u get after 2 week ?
    • kingarthur
      • 1369
      This doesn't have a toner hopper, toner goes from bottle, straight into IU - have you double checked the customer has removed the tape from the toner bottle, also- I've just had this, can you take the toner bottle out, and manually turn it, i had a bottle clogged up
      • albemero
        • Apr 2019
        • 37
        Hello.
        New FW
        Initializ and Stabilization with PC1 opened
        Print out a few gradation pattern 256 for that color
        Repeat from start again.
        Gesendet von meinem SM-S901B mit Tapatalk
        • avio2
          • Jul 2010
          • 150
          Originally posted by albemero
          Hello.
          New FW
          i already did 2 time
          now : manual stirring oly i.u and machine work , only TCR 6,2 but this is bad!!!!!
          total couter 5000 and 3 i.u k
          • avio2
            • Jul 2010
            • 150
            tape iks remover and crtridge toner work
            • occus
              • 337
              New Firmware GC2-Q9 is recommended.
              Fix
              "2. Prevent abnormally high toner density detected TCR sensor (C2552/C2554/C2556/C2558) after initial setup of the machine or replacing IU."
              • stronghold
                • Apr 2023
                • 47
                [ATTACH]61732[/ATTACH]
                [ATTACH]61733[/ATTACH]
                [ATTACH]61734[/ATTACH]
                I hope you find this information useful.
                Best wishes.
                • Tech09
                  • Apr 2020
                  • 145
                  On all these smaller machines if I have a problem with toner I take the HV unit out and clean the contacts and springs with a green scrub pad.
                  • stronghold
                    • Apr 2023
                    • 47
                    Not necessarily. I have exactly the same problem on the Bizhub PRO 958.
                    If the device is left unused for more than 2-3 weeks, then the toner starts to clump together and turns into stones.
                    I have described all the symptoms above. The problem is in reducing the diameter of the toner to increase DPI.
