Bizhub C364e stuck on for bars
  • otphas
    • Aug 2019
    • 121
    Hi folks ,
    bizhub c364e stuck on 4 bars. Installed new SSD and fresh firmware- same result , Dimm was changed no luck again. Installed firmware and all was complete. Behind on the mfp shining 3 leds and in front panel shining sub power - blue and start button orange. In some time as machine is on 4 bars start button stop shining and behind isntead of 3 leds shining 2 leds. Any idea ?
  • Synthohol
    Certified Konica Expert
    • 5871
    Re: Bizhub C364e stuck on for bars
    did you boot to a firmware stick and enter the proper machine and type?
    should not show FF
    • otphas
      • Aug 2019
      • 121
      Hi ,
      for sure firmware machine and type are correct! I think for Bizhub C364e is 3-1 !
      • tsbservice
        Field tech
        • 8032
        What about backup battery?
        • otphas
          • Aug 2019
          • 121
          3.26V
          • otphas
            • Aug 2019
            • 121
            Do you have explanation about red leds on the mfp , what they mean , i think is a code and if we know what mean we can find a the problem. Is it have also mfp ICP list and location to check them 1 by 1 ?
            • tsbservice
              Field tech
              • 8032
              Nothing I've heard of. Remove any options and do firmware again.
              • otphas
                • Aug 2019
                • 121
                Adf is disconnected and PC110 too, not other option attached. My firmware is G20-J9, did you prefer other Ver ?
                • tsbservice
                  Field tech
                  • 8032
                  Firmware is old but as long as it takes it should be good enough. However I would do update with one of latest versions just in case.
                  • Synthohol
                    • 5871
                    i sent you g20-M1
                    • otphas
                      • Aug 2019
                      • 121
                      Will try it tomorrow and let you know.
                      • otphas
                        • Aug 2019
                        • 121
                        Same result with G20-M1, the machine stuck on 4 bars!
                        • copier tech
                          • 8195
                          You may have a failing HDD if you have a spare try that.
                          You could also try the NVRam reset tool.
                          • otphas
                            • Aug 2019
                            • 121
                            Hdd was swapped with other and Tar file was tried , nothing. This machine make me crazy.
                            • aberock
                              • May 2022
                              • 127
                              why not try get new ram ?
                              4 bar but can't boot can try ram 😊
