IC-414 Fiery disassembly Konica C754E
  • ferro10
    • Jun 2015
    • 117
    Hi everyone
    I have a customer with a Konica C754 with this warning message "Turn on controller"
    Considering that the customer is no longer needed Fiery is there any particular procedure for removal?
    Thank you
  • copyman
    Owner / Technician
    • Sep 2005
    • 4764
    Re: IC-414 Fiery disassembly Konica C754E
    Originally posted by ferro10
    Hi everyone
    Thank you
    Remove Fiery & interface board on rear of machine. Then go into service mode (System 2, Image controller) and set controller to "0". That is all you have to do.
    • ferro10
      • Jun 2015
      • 117
      Thanks for the reply
      • Synthohol
        Certified Konica Expert
        • 5892
        technically you don't have to physically remove it, just changing the controller type to 0 will ignore the fiery and interface board and use only the emperon embedded one. just power it off and remove the network cables
        • copyman
          Owner / Technician
          • Sep 2005
          • 4764
          Synthohol is correct if you don't want to remove. But since you asked specifically "is there any particular procedure for removal" I posted on how to remove. Not a big deal to remove. Will take maybe 10 mins at most.
          Attached is the IC414 install instructions, just reverse procedure.
