Banding Along Short Edge
  • garethmrn
    • Jul 2017
    • 18
    Hi All,
    Recently replaced a few items on a KM C3080 and am getting these issues, wondering if anyone has any ideas as to why?
    Replaced Drums, Coronas and Transfer Belt /H
    Any help would be appreciated.image005.jpgimage004.jpgimage003.jpgimage002.jpgimage001.jpg
    • 23010
    Re: Banding Along Short Edge
    No gradations of yellow?
    The bands in the feed direction look like dirty primary charge coronas ... can't tell which from your images.
    It would be helpful to have these images for diagnosis:
    • Ziggy
      • Feb 2018
      • 789
      Originally posted by garethmrn
      Hi All,
      Any help would be appreciated.[ATTACH=CONFIG]61079[/ATTACH][ATTACH=CONFIG]61080[/ATTACH][ATTACH=CONFIG]61081[/ATTACH][ATTACH=CONFIG]61082[/ATTACH][ATTACH=CONFIG]61083[/ATTACH]
      Its hard to tell what your problem is with these pictures. A description of the problem along with pictures would help
      • garethmrn
        • Jul 2017
        • 18
        Have tried these but they don't seem to be showing the issue, I have scanned and attached them, also attached a scan of the Orange where it showing up quite a lot, they are darker bands about 2inches wide with a 5.5inch gap between, they are not fixed moved around sometimes, however some instance they are pretty much in the same place.
          • 23010
          Where are these images? Not attached to your post. =^..^=
          • garethmrn
            • Jul 2017
            • 18
            Not sure why but the pdfs didn't upload, jpegs attached
              • 23010
              Definitely magenta drum. The interval for the drums is 188mm (5 1/2" + 2" = 7 1/2" = 190.4mm). You can also see it in the Henry Ford blue.
              You should be able to swap drum locations and watch the color change. =^..^=
              • Ziggy
                • Feb 2018
                • 789
                Run a test print 43 and that will print out a half tone and a full density of each color plus other colors . then you may be able to isolate it to one color.
                • Ziggy
                  • Feb 2018
                  • 789
