Konica C759 soft switch settings when updating several firmware versions
  • MarioTech
    • Jul 2020
    • 48
    Hello guys,
    thought I'd reach out to the community after finding out KM removed the firmware and all documentation on the C759 series for everyone or maybe just independent distributors like me. So basically I need to update the firmware to the latest version which I have, however I can't access previous versions to update 2 versions at a time, so last year I remember updating another C759 from several versions behind to the latest and changing a soft switch to prevent error codes, lock ups or board damage. This time I am outta luck as the docs aren't available for me any longer, they used to have a read me sheet with all the information related to the firmware version and on those notes the soft switch values were shown as well as the number of the switch. Hope someone has the notes for this and can help, thank you in advance!
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 162
    Re: Konica C759 soft switch settings when updating several firmware versions
    Here's the latest FW:
    Version GCP-Y2 Function Version 4.2
    1/2/2024 439.55 MB FW A8JE0Y0-F000-GCP-Y2.exe Release Notes: [bizhub C659_C759] [FW ver. GCP-Y2] Function Version4.2 Periodic ROM.
    SEE DLKM_BT2317452EN
    and the instruction PDF:
    1/2/2024 120 KB bizhub C659 C759_DLKM_BT2317452EN_01.pdf Release Notes: [bizhub C659_C759] [FW ver. GCP-Y2] Function Version4.2 Periodic ROM.
    README DLKM_BT2317452EN
    in case you cant access the links, here's the soft switch info
    Switch No.: 25
    HEX Assignment: A0 -> Function Version 4.1
    HEX Assignment: B0 -> Function Version 4.2
    • MarioTech
      • Jul 2020
      • 48
      Thank you very much FuserNoob, that's exactly what I was looking for! I was about to call KM to get this but they can be quite challenging to persuade when providing information for smaller independent distributors like me. I really appreciate the information provided!
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 162
        No Problem, MarioTech!
        I'm in exactly the same boat and feel your pain!
        • thiepmint
          • Apr 2022
          • 2
          Movie_A8JE0Y0C000 G0090_F4.2.exe
          Voice Data Voice_A8JE0Y0C100 G0091_F4.2.exe
          Can you give me these 2 files, please
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5892
            i PM'd you movie data.
            voice i cant help, sorry.
            thanks for being a contributor though
            • Stech2003
              • Apr 2024
              • 19
              You should be ok without the voice data unless you have an added option that requires it. When the movie data file is missing, it is the only one that will pop up the message at the top of the screen.
                • 8200
                Originally posted by MarioTech
                Hello guys,
                It is usually ok to update to a latest version 'jumping' multiple older previous versions, the C759 is a sold model.
                We do occasionally see issues doing this on the 4e series.
                In future if you're stuck for any KM firmware give a shout via either site below.
