Konica minolta c224e nova baterija
  • M1963
    • Jun 2017
    • 67
    greetings servicemen,
    so far I have replaced three batteries on minolt c224 devices and after each replacement the counters go to 0. (after I put a new battery I reset it with A145FW-Reset)
    that doesn't suit me at all since the machines are leased and the initial counter is in the contract.
    have any idea what I'm doing wrong.
  • Toxic
    • 698
    Re: Konica minolta c224e nova baterija
    Why use reset fw if you dont want to clear counters?
    • M1963
      • Jun 2017
      • 67
      Hm.. good question,
      I read somewhere that this is the procedure when replacing the battery.
      I haven't tried without a reset.
      thanks for the suggestion.
      • Synthohol
        Certified Konica Expert
        • 5879
        in enhanced service mode you can choose restore data (if button is avail)
        that will get your meters back usually
        • M1963
          • Jun 2017
          • 67
          does the option apply only before the reset or does it give the option after the reset as well ?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4750
            Are you soldering in new battery before removing old?
            My experience has been once battery is dead all the counts are lost and most of the time Non-recoverable.
            • tsbservice
              Field tech
              • 8042
              We had it once when machine lost some random numbers from color and black counters. Go figure.
