Firmware for C364e
  • konicar
    • Jan 2024
    • 9
    Firmware for C364e
    Hi friends,
    could anyone provide me a source for the last firmware for Konica Minolta C364e?
    After the factory reset everything is gone e.g. functions like AirPrint
  • copier tech
    • 8164
    Re: Firmware for C364e
    Originally posted by konicar
    Hi friends,
    We can supply you with the latest version of firmware should you still require it.
    Printer Firmware Download
    โ€‹
    • rrrohan
      • Sep 2011
      • 1977
      if AirPrint worked prior you shouldnt need firmware. from memory AirPrint wasnt even a option until you upgraded to a function version that supported it. Im guessing the SW25 has just reverted back to lower amount
      • konicar
        • Jan 2024
        • 9
        Yes - AirPrint worked before.
        Now it shows Version 2 in the device information.
        Is it possible to restore prior function amount?
        ROM Version
        MFP Card Version A5C10Y0-F000-G20-41(00)
        MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
        MFP Controller Linux Base Linux-2.6.26.8-rt16
        MFP Controller Kernel Program A5C10Y0-1C00-G00-08
        MFP Controller SubSet A5C10Y0-1F00-G00-02(00)
        MFP Controller A5C10Y0-0100-G20-41(00)
        Operation Panel Message Data A5C10Y0-8100-G00-14
        Fax Board Controller1 A22M0Y0-4000-G00-06(00)
        Fax Board Controller2
        Engine Parameter A5C10Y0-0054-G00-00
        Engine BOOT A5C10Y0-0055-G00-00
        Scanner A5C10Y0-0023-G00-02
        Printer A5C10Y0-0050-G00-06
        ADF A3CF0Y0-0024-G00-11
        Finisher
        RU
        ZU
        Panel CPU A55V0Y0-8900-G60-00
        DSC1
        DSC2
        Loadable Device Driver1
        Loadable Device Driver2
        SD
        Voice Data
        Movie Data
        Dictionary Data
        OCR Library
        Panel Sound Data A5C10Y0-C200-G00-00
        MFP Controller conversion file
        MFP Controller System A5C10Y0-1000-G20-41(00)
        MFP Controller Print Controller A5C10Y0-3000-G00-P0
        MFP Controller Print Controller Font A5C10Y0-3F00-G00-P0
        MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-01
        MFP Controller MIO A5C10Y0-5000-G00-06(00)
        MFP Controller PIC A5C10Y0-8200-G00-01
        • copier tech
          • 8164
          ROM Version
          Finisher
          RU
          ZU
          DSC1
          DSC2
          SD
          Voice Data
          Movie Data
          Dictionary Data
          OCR Library
          Set SW25 to HEX 60 in CE mode this will enable function version 7 after a power cycle.
          You will then have the option to enable Airprint in Network settings.
          โ€‹
          • konicar
            • Jan 2024
            • 9
            The clearing procedure was "Clear All Data".
            After that AirPrint was gone.
            Now - the printer doesn't store the setting SW25 to HEX 60
            • Synthohol
              Certified Konica Expert
              • 5837
              is the HDD turned on?
              • B0265
                • Jan 2007
                • 718
                The information I have says that you need FW version G20-J6 (G00-J6) or later to enable AirPrint.
                I think G20-41 is function version 2 so it is interesting that it did work earlier.
                • Synthohol
                  • 5837
                  ck your PMs
                  • konicar
                    • Jan 2024
                    • 9
                    yes
                    • konicar
                      • Jan 2024
                      • 9
                      ck your PMs
                      Thank you very much!
                      • konicar
                        • Jan 2024
                        • 9
                        I guess I had the wrong informations from the user.
                        The user was able to print from iPhone while the printer was recognized in it. I understood that was the AirPrint function.
                        After "clear all data" the printer is not recognized and shown by the iPhone. But it still can used to print at the laptop (Mac OS).
                        1. Can you tell me which FW ist newer or better: GDU-M1 oder G20-M1?
                        2. Is is possible to update it directly from G20-41 up? (or too big jump at once?)
                        3. Does anywhere exists a listing of all the releases of this firmwares?
                        Thx
                        • konicar
                          • Jan 2024
                          • 9
                          After flashing G20-M1 AirPrint works, but has some issues.
                          The iPhone now sees the printer i can print. On the printer side the order comes but is discarded some times over and over again till it prints finally. In the order list this only one print order appears as many discarded orders.
                          Any idea?
                          • B0265
                            • Jan 2007
                            • 718
                            There is a problem with the latest iOS:
                            4e AirPrint firmware updates? Latest iOS
                            • konicar
                              • Jan 2024
                              • 9
                              Thx!
                              that might be the explanation
