C308 connection conundrum
  • Tech09
    • Apr 2020
    • 147
    I have a C308 that prints great, no problem there at all. But it can't be pinged, can't connect to the web interface and can't scan. I ordered a new MFPB. Just curious if anyone has experienced such lunacy.
  • Tech09
    • Apr 2020
    • 147
    Re: C308 connection conundrum
    Originally posted by femaster
    EDIT: Redacted, didn't read closely enough.
    You were going to suggest replacing the MFPB? lol yeah, that's why I said that because I figured peeps would be screaming that.
    • femaster
      • May 2011
      • 1519
      No, actually I was starting out real simple and basic, but breezed over the first part about being able to print, so I had foolishly asked if the network lights on the port were working. We already know the answer to that however.
      • Synthohol
        Certified Konica Expert
        • 5891
        Did you go through Admin mode and make sure that it's even turned on? http server I mean.
        • allan
          RTFM!!
          • 5462
          You can try to initialize the network setting data. That will also set all the protocol settings to default.
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            if network settings initialised packet filtering is enabled by default (in my marketing region anyway) and if what you are connecting to it from is on a different IP range this will give you these symptoms. Check the quick security settings.
            • Lync
              • Feb 2016
              • 47
              Log into Admin mode on the screen of the machine not the web browser and disable SSL/TLS in TCP Socket Setting (Admin - Network - TCP Socket Setting) - You will re activate this later
              then make sure Web Browser is enabled (Admin - Network - Web Browser Setting) - You might want to remove this from the front Menu screen later, but keep it enabled.
              I think on a C308 you might need to get a license for web browser if it hasn't already got one, at: License Management System
              • tsbservice
                Field tech
                • 8052
                Yes happened a couple of times. Did Initialize all and redo setup, that solved it but I like your idea and saved in text file - "can print-no ping-no PSWC-no scan"
