Bizhub C224 - printing problem
  • woji
    • Jun 2020
    • 5
    Hello, can I ask the more experienced for help?
    A few days ago, the printer started printing a stripe (see scan). I found that after printing approx. 5-6 papers the error disappears.
    Subsequently, if there is no printing for, say, 2 hours, the bar will appear again. I thought the drum would be defective, so I tried replacing it as a test (I have a spare in stock), but the problem is the same - maybe worse.
    Has anyone encountered this problem, or how to solve it?
    Thank you very much for your help
    SKMBT_C22424030814340.pdf
  • copyman
    Owner / Technician
    • Sep 2005
    • 4683
    Re: Bizhub C224 - printing problem
    [ATTACH]61919[/ATTACH]
    Transfer belt. You can try and remove trans belt unit, remove cleaning assembly on unit, vac & clean blade, lube blade with yellow toner and reinstall. If that don't work you need to replace transfer belt.
    • woji
      • Jun 2020
      • 5
      Thank you Copyman for your reply.
      Unfortunately, the situation is the same and there has been no improvement. The problem still persists
      ...so I will have to buy a new belt.
      • femaster
        • May 2011
        • 1501
        Based on the sample, definitely the belt as copyman stated. That is what one of the two calibration stripes look like after the cleaning blade attempts, but fails, to clean it off the belt surface.
        • doinbox
          • Jan 2013
          • 107
          Put your a4 paper Landscape in the cassette and if the lines at the edge of the belt it won't show on your prints. (temp fix)
          Ignore this I didnt see your sample originally but I can tell putting the paper landscape won't help
          • woji
            • Jun 2020
            • 5
            Ok, I'll get a new belt.
            I am currently using the printer in the landscape position, but I definitely want to solve the problem in the future. D
            Thank you all for your help and answers.
            Have a nice and peaceful weekend
