Firmware Help
  • mkdirs
    • Oct 2014
    • 177
    Firmware Help
    Hello every one
    This is the first time trying to upgrade the software
    i have 2 machines
    first Konica 758 B&W With firmware A7950Y0-3000-G00-P3
    second Develop develop ineo 758 B&W With firmware A7950Y0-3000-G00-R2
    I discovered that the two devices are the same
    I have A7950Y0-F000-G00-Q1 FIRMWARE
    I'm trying to use it by extracting the file
    And copy all the contents of the file FW004 to usb root with FAT23 format
    When the machine boots up it goes straight to the home screen and I can't get into update mode
    What mistake am I making?
    thanks
    Xerotk.com
    xerox copier technician
  • Synthohol
    Certified Konica Expert
    • 5901
    Re: Firmware Help
    the whole FWxxxx folder goes on the root of the flashdrive as is.
    dont extract nothing past the original .exe self extractor to see the FWxxxx folder.
    • mkdirs
      • Oct 2014
      • 177
      Re: Firmware Help
      Thanks for your quick response
      1- I downloaded the A7950Y0-F000-G00-Q1.exe
      2- I Extract the .exe file
      3- i get 2 folders and .bat file
      cw Folder
      FW0004 Folder
      mktar_A795.bat file
      4- I copy FW0004 Folder to the root of the rm disk ( the copier dose not go to update screen )
      5- I copy all files from FW0004 Folder to the root of the rm disk ( the copier dose not go to update screen )
      i do Exactly like #Konica #Konicacopiers How to install firmware on Konica Bizhub C754/C654 - YouTube
      Xerotk.com
      • mkdirs
        • Oct 2014
        • 177
        Re: Firmware Help
        Ok Thank you all its done
        I Power On the machine with yellow button pressed then i get the update screen
        i have the A7950Y0-F000-G00-Q1 firmware since 2017
        any one can help with newer version
        thanks.
        Xerotk.com
        • Synthohol
          • 5901
          Re: Firmware Help
          i have y1 and y2.
          see PM
          • copier tech
            • 8213
            Re: Firmware Help
            cw Folder
            FW0004 Folder
            mktar_A795.bat file
            The C754 & your 758 use a different update process.
            Copy your FW0004 folder to your USB & plug into the USB port near the control panel. Power on the device while holding down the stop (red) key.
            Bizhub 758 958 GCQ-Y2 Firmware Readme.pdf
            • mkdirs
              • Oct 2014
              • 177
              Re: Firmware Help
              [ATTACH]61928[/ATTACH]
              thanks friend
              done holding down the reset (yellow) key.
              Xerotk.com
