Konica C558 noisy scan from ADF
  • ferro10
    • Jun 2015
    • 117
    Hello everyone
    I have a Konica C558 that emits strong gear noises that jumps during the scan from ADF
    The jumping gear is the one circled in the photo seems not correctly coupled with the other.
    I tried to hold down the upper counter to bring the two gears closer. The noise disappears and works without problems
    IMG_20240312_162425426_HDR.jpg - Google Drive
    Is there any technical bulletin for this problem? Has it ever happened to you?
  • Brad6784
    • Mar 2015
    • 83
    Re: Konica C558 noisy scan from ADF
    Looks like the gear is just worn to me, if it is, obviously replace both gears.
    Of course it could just be the photo, good luck!
    • Gift
      • Mar 2011
      • 2459
      Is that gear part of the feed assy wich sits in the df door/cover?
      I think I had an issue once that the door seemed closed and locked but the pin for the lock lever was a little bent.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4750
        Originally posted by ferro10
        Hello everyone
        I've had this many times. If the rear latch hook on top cover isn't broken then the rear hinge pin for top cover has come out. Remove rear cover and look where the top cover hinges and you will see the pin has come out and laying below hole it goes in. I put some glue on screw that holds pin in.
        • elmaligno
          Expert technician KM
          • Oct 2009
          • 302
          I agree, this happens a lot of times, you have to bend the locking pin down a little bit.
          Field technician since 1994
          • ferro10
            • Jun 2015
            • 117
            Thanks everyone for the reply
            I removed the two screws and the two pins that keep the upper counter stop
            When I reassembled everything by tightening the two screws well that are fixed on the two pins the problem has disappeared.
            Tomorrow morning I do more tests to be sure that the problem does not appear.
