C450i message
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    C450i message
    Just bought this off lease machine and this message is showing, "The PDF / A font was not found. Please contact Service rep" Does this mean it has a License kit, if so which LK and how to get rid of message? How do I see what LK's are installed in machine?
    Thanks in advance
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: C450i message
    Thanks in advance
    PDF/A scan function is standardized in the firmware G00-E9 and later versions.
    Therefore, PDF/A function that was provided by LK-102 will be enabled once the firmware is installed. If PDF/A Font Data is not installed, the error message will be displayed.
    Please be sure confirm PDF/A Font Data is installed in the machine when installing this firmware. Refer KNOVA-PS "PSKM_BT2022690EN" for details.
    Field technician since 1994
    • elmaligno
      • Oct 2009
      • 302
      Re: C450i message
      Thanks in advance
      I-option_AA2J0Y0-B200-G00-01_PDFAFontData.exe
      • tsbservice
        Field tech
        • 8064
        Re: C450i message
        It's just like Movie data(Animation guide). Download it in and install in System 2 - Install data.
        • Synthohol
          Certified Konica Expert
          • 5905
          Re: C450i message
          copyman, your inbox is full.
          i have link for you.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4785
            Re: C450i message
            Thanks for letting me know about inbox. I emptied and should be good now.
            Thanks again!
            • copyman
              Owner / Technician
              • Sep 2005
              • 4785
              Re: C450i message
              Is there a way to see what LK's are installed?
              Can the home screen be set to classic style permanently?
              • tsbservice
                Field tech
                • 8064
                Re: C450i message
                [Utility]
                [Administrator]
                [System Settings]
                [Main Menu Display Settings]
                Edit my mistake:
                [Utility]
                [Administrator]
                [System Settings]
                [Default Operation Mode Settings]
                • tsbservice
                  Field tech
                  • 8064
                  Re: C450i message
                  copyman in the link are attached 2 pics, one is how to set permanent Classic style and other is where I believe in web page you can see which Licenses are installed(our machine don't have one).
                  Secure Swiss File Transfer & Decentralized Storage | WeSendit
                  • Synthohol
                    • 5905
                    Re: C450i message
                    link sent
