C224e strange message
  • jwai
    • May 2018
    • 508
    Hello,
    One C224e showed " enter serial number ", after I initialized the machine and rewrote firmware, it recovered.
    I found " fax is unavailable " displayed, but the machine don't have fax kit and System 2->option board->fax 1 /fax 2->unset.
    How can I solve it?
  • HoonBoy
    • May 2011
    • 130
    Re: C224e strange message
    Originally posted by jwai
    Hello,
    How can I solve it?
    Battery of the NVRAM on MFP Board empty. Needs new MFP board.
    • allan
      RTFM!!
      • 5462
      Hello,
      How can I solve it?
      Agree that the NVRAM battery is bad. Check under trouble isolation it the fax option is set if so unset it.
      Whatever
      • jwai
        • May 2018
        • 508
        I checked trouble isolation and all unset.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4700
          Agree that the memory battery is bad or going bad. No need to replace MFP board. You can just replace the battery. Solder in the new battery before removing the old one. This way you wont lose all the counters & serial #'s
          If you search this forum about "4" series and batteries you will find some good info.
          • copier tech
            • 8144
            Hello,
            How can I solve it?
            Try the NVRam reset tool this can help.
