Bizhub C368 Reboots on large copy job
  • VolatileCoronaWire
    • Dec 2022
    • 5
    Hey guys,
    A copy job of 99+ pages was done on this C368 and halfway through printing the job, it rebooted and started the job over again, wasting paper and toner. I checked the hard drive and did a full self-diag, and everything looked fine. No codes besides E4-2, which I hear is normal if you don't have an external memory unit installed. I checked the related counters, and there were no details other than it rebooted. The service manual doesn't have anything to say about this from what I've seen. Any tips?
  • Duplicator
    • May 2022
    • 255
    Re: Bizhub C368 Reboots on large copy job
    Have you tried running the copier's self diagnostic mode?
    1. Power off copier
    2. Hold down power button on screen.
    3. Power on copier.
    4. Wait for black dot on the corner of the display
    5. Let go of the power button
    6. Once it boots and the start light turns blue, hit start.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
      • 23010
      This sounds a lot like a C-2557 situation. As the toner density lowers it will eventually code out. If you don't happen to be standing there at the moment it happens, you won't see the code. Then it will automatically reboot, and during initialization it may acquire enough toner to start printing again, from the beginning.
      To be sure the error is displayed and recorded go to System2 > Internal Error. Auto Cancel > set Rank B & Rank C to NO.
      • tsbservice
        Field tech
        • 8048
        Originally posted by VolatileCoronaWire
        Hey guys,
        No trouble codes in history?
        At what firmware and function version is machine?
        Does it restart on certain print job/file?
        • copier tech
          • 8196
          Hey guys,
          Does the C368 literally restart while a job is running so when it powers back on it has a jam etc ?
