biz 501 drum
  • Gab
    • Aug 2015
    • 671
    biz 501 drum
    I replaced drum and blade in the machine (drum compatible not Genuin) following the proper procedure. Image is ok but Customer wants to be a little lighter not so dark. What programs to execute ?
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5827
    Re: biz 501 drum
    LD1 & LD2 adjustments adjust so the shading blocks are just barely visible between the target area.
    evenly for both 1 & 2.
    make sure the drum counter was cleared too.
    • Gab
      • Aug 2015
      • 671
      Re: biz 501 drum
      ID sensor error appeared. Also indeed copies are lighter now but it does not copy grey color. Any suggestion?
      • Synthohol
        • Mar 2016
        • 5827
        Re: biz 501 drum
        i have been very fortunate to never have to use aftermarket supplies unless it was an emergency and we returned with genuine once it shipped. also 9/10 times drum and developer were always changes at the same time and with OEM so i dont know any tricks that werent in the service manual.
        was this one of the models you had to adjust the charge grid voltage to whats stamped on the back cap of the drum? its been a while since ive played with dinosaurs
        • femaster
          • May 2011
          • 1504
          Re: biz 501 drum
          Sidetracking here a little bit.
          I can't recall about voltage printed on the drum for the 501 model either, but I know the likes of the 600/750 601/751 did have the voltage printed on them. We had tried some generic drums for that model briefly, and the funny part was, every single one of those generic drums had the exact same voltage printed on them. My best guess is they picked a number somewhere in the middle and just printed it on every one they made.
