Konica Bizhub C754e Firmware (will donate)
  • Supertechs
    Will work for Firmware
    • Nov 2014
    • 9
    Hello there,
    I'm looking for the lastest firmware for the Konica C754e.
    I have the firmware from 01/23/2023 (GDU-M0) was wonding if there is anything newer.
    I will donate 10 dollars.
    https://www.supertechs3.com/
    https://www.youtube.com/@Supertechs3
  • Ziggy
    • Feb 2018
    • 802
    Re: Konica Bizhub C754e Firmware (will donate)
    Originally posted by Supertechs
    Hello there,
    That is the latest for that model
    • Supertechs
      • Nov 2014
      • 9
      Thank you!
      • copier tech
        • 8200
        Hello there,
        Most likely this will be the last update for a while for the old 4e series.
        Bizhub C654e C754e Firmware Readme GDU-M0.pdf
        • Stech2003
          • Apr 2024
          • 19
          It is the most current and probably the last unless there is an update due to some type of security vulnerability.
          Version GDU-M0 is Function Version7, Change Software Switch Setting in Service Mode to:
          Switch No.: 25
          HEX Assignment: 60
