c458 and pc-415
  • romario
    • Jun 2020
    • 193
    c458 and pc-415
    hi group, i have a km c458 with pc-415, the machine works durin 1 or 2 week, then it is deactivated pc-415, i have go to activate it and it works again. I change A2XMH00301 PWB Assembly(PWB-CB_L ASSY) and continue the problem
    thanks
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: c458 and pc-415
    what code is in history after it happens?
    • romario
      • Jun 2020
      • 193
      Re: c458 and pc-415
      It does not give an error code, I forgot to add that during the day when the PC-415 is deactivated at 5, 6 hours, the machine itself restarts and the PC-415 is activated again
      [COLOR=var(--COEmY)]
      [COLOR=var(--IXoxUe)]
      [/COLOR][COLOR=var(--IXoxUe)]
      [/COLOR]
      [/COLOR]
      thanks
      • Synthohol
        • 5905
        Re: c458 and pc-415
        it may not be on the screen but is there in history?
        may show a stop code in the list output?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4785
          Re: c458 and pc-415
          [/COLOR]
          [/COLOR]
          Probably restarting with "internal error". Good advice from Synthohol to see what the "hidden" error code is.
          • emujo2
            • Mar 2017
            • 1579
            Re: c458 and pc-415
            The PC is experiencing an issue that allow "isolation". Message is displayed on the LCD "push button to continue use without PFU". Once main power is cycled the machine goes through the same process. There must be a code in error history or if it's on KM's Vcare you could see it here as well.
