Windows Defender Infohub Firmware issue
  • doinbox
    • Jan 2013
    • 121
    Hi everyone just wanted to warn you all the latest updates to windows defender seems to be causing issues when extracting Konica firmware zips. Its deleting tar files whilst extracting causing the firmware to no longer work. We've had to disable it for now.
  • tsbservice
    Field tech
    • 8061
    Re: Windows Defender Infohub Firmware issue
    Thanks for warning us. Do you happen to know how can we check if Defender is actually breaking our firmware folders without obvious way on the machine itself?
    • doinbox
      • Jan 2013
      • 121
      One way would be to take a snapshot of all the files in the zip before extracting. And then check your extracted files against it.
      • Duplicator
        • May 2022
        • 260
        If you have 7-Zip installed just open the firmware self extracting EXE with 7-Zip's file manager. It will list all the files inside. It can even extract them if needed.
        I haven't been able to reproduce the behavior your seeing but it may just be the self extracting EXE setting it off.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • doinbox
          • Jan 2013
          • 121
          7 zip is what I use with windows 10.
