Konica C3350i administrator or smtp email address conflict - scan to mail
  • mano972
    • Apr 2024
    • 12
    Hello,
    Bizhub C3350i
    Rom Version A93E0Y0-0100-G00-N4(00)
    Sorry for my english I'm French.
    When I try to scan to mail I immediately get an error on Konica and I noticed during a packet analysis with wireshark that the Konica machine had not taken into account the modification of the email address, it's the same as the old one on wireshark "copieur.konica@ch**.fr and not the new "copieur.konica365@gh**.fr", this email address should not be present in the frame, yet everything is configured well, I have the same problem with another konica, where can it come from?
    Imgur: The magic of the Internet
    Thank all
  • mano972
    • Apr 2024
    • 12
    Re: Konica C3350i email address remains unchanged - scan to mail
    the size of the images are too small I posted the images on this link
    thanks for the feedback
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5823
      Re: Konica C3350i administrator or smtp email address conflict - scan to mail
      there is a space before the letter C in this entry?
      • KMFLT3CH
        • May 2017
        • 232
        Check the scan settings, sounds like the from email was changed and then set as default.
        Scan/Fax button, then go to Name/Subject/File Name at the bottom and check the email there.
        Change it if necessary, then set it a default, follow this video: Konica Minolta bizhub C250i - How to Modify Default Scan Settings - YouTube
        • mano972
          • Apr 2024
          • 12
          no space
          • mano972
            • Apr 2024
            • 12
            From the web interface everything seems to be good, to see on the physical machine, I will only be able to check tomorrow
            • mano972
              • Apr 2024
              • 12
              the email address on wireshark came from the certificate section
              solved by recreating the certificate
