BIZHUB C300i NEW SSD PREPARING
  • Duplicator
    • May 2022
    • 250
    #16
    Re: BIZHUB C300i NEW SSD PREPARING
    I've attached the boot up troubleshooting guide from Konica. I recommend following it as it will walk you through testing different failures.
    Originally posted by bmn
    I tried to use "tesdisque" with the old SSD but it was inaccessible. maybe it is encrypted
    Generally they aren't encrypted. Does the copier startup off of the firmware update usb stick? If so, the copier is fine and there is just something wrong with the SSD. When installing a new SSD, they come from Konica completely blank. The firmware updater formats them. If partitions exist it tries to use it without formatting. So one trick is to format it with a computer to wipe out the partition table so the firmware updater writes a new one.
    Where can i download the diagnosis and recovery tool? can you send it to me?
    As far as that tool goes you can get it from Konica's dealer page. I don't have a way to host it and send it to you. If you aren't a registered dealer, Copier Tech on this forum sells them from his website or if you donate to the forum there is a chance someone will send it to you.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • bmn
      • Apr 2024
      • 12
      #17
      If you have the tool you can use wetransfer and just give me the link to download it
