BIZHUB C300i NEW SSD PREPARING
  • bmn
    • Apr 2024
    • 12
    How to install a new SSD on bizhub C300i which stops on Bootup at 25%.
    can we format it on the computer, if so what type of partition and formatting should we choose
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: BIZHUB C300i NEW SSD PREPARING
    1-deleting partitions and formatting in fat 32
    2-It is not a computer SSD, it has to be KonicaMinolta. If it is a model more updated than the one the machine had, you have to boot with the pen with the firmware and load the boot rom, as described in the service manual.
    3-Place in the machine and wait for the recover data to run.
    Field technician since 1994
    • copytechtrouble
      • Nov 2020
      • 110
      no need to partition it. just delete all partitions and leave it blank. the machine will format and partition it when its installed.
      you'll need the PDF/A Font and Movie Data and you'll have to reinstall the scans/user boxes and any other service settings that you use with it.
      only the meters and consumable data is carried over when the SSD is replaced.
      just a heads up though, in my experience a machine stuck at 25% or 50% on boot is almost always caused by the CPUB.
      • Duplicator
        • May 2022
        • 250
        Have you run the diagnosis and recovery tool? It might be possible to recover some data from a bad SSD or bad CPU board before replacement.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • bmn
          • Apr 2024
          • 12
          When started with usb FW to update the machine FW with the new SSD, the MFP CONTROLLER strated and finished with Download N.G message and SCANNER/PRINTER finish with Download completed message.
          with the old SSD he MFP CONTROLLER strated with 10% Download and finished with Download N.G message.
          Is there any method to format the SSD from the usb FW?
          • bmn
            • Apr 2024
            • 12
            How the machine will format and partition the SSD without booting up and using service mode?
            • bmn
              • Apr 2024
              • 12
              Where can i download the diagnosis and recovery tool?
              can you send it to me?
              • copytechtrouble
                • Nov 2020
                • 110
                Just put a blank SSD in and boot with, and run, the firmware.
                The machine will reboot into 'recover data' hit that and reboot again.
                It should be back to (mostly) factory settings.
                • copytechtrouble
                  • Nov 2020
                  • 110
                  In this case I'd be almost certain that your problem is the CPUB, not the SSD.
                  Do you still have the original SSD? You are not ment to put in a new CPUB and SSD in at the same time.
                  • bmn
                    • Apr 2024
                    • 12
                    • bmn
                      • Apr 2024
                      • 12
                      • Albonline
                        • Sep 2008
                        • 1153
                        if this is true ,reinstall original ssd and do logical format from service mode. if you must format and remove old system from a corruped drive. try testdisk freeware . remove all partitions.
                        • bmn
                          • Apr 2024
                          • 12
                          my question is how to access the service mode from the firmware usb key since the machine no longer starts
                          • copytechtrouble
                            • Nov 2020
                            • 110
                            Have you tried holding down the reset key on boot and get into service mode from the recovery console?
                            • bmn
                              • Apr 2024
                              • 12
                              I tried to use "tesdisque" with the old SSD but it was inaccessible. maybe it is encrypted
