Konica Minolta C454e Repeat Image
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C454e Repeat Image
    Hi All
    Getting repeat image. Replaced all the drums and transfer belt unit.
    Please find the attached and advise
    Many thanks
  • tsbservice
    Field tech
    • 8064
    Re: Konica Minolta C454e Repeat Image
    I will check/clean drum Led erase.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4785
      I see you posted drums were replaced but you still have an issue with the yellow drum. Were the drums genuine kon/min?
      Very easy to troubleshoot, swap yellow drum with the cyan or magenta and see if the repeat image changes color.
      • aberock
        • May 2022
        • 132
        Originally posted by mearmi
        Hi All
        Many thanks
        replace cleaning blade.
        can try by swap yellow with other IU see same problem or not
        • Ziggy
          • Feb 2018
          • 810
          what is the fuser life/ condition ?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4785
            Yes a bad fuser can cause a repeat / ghost image but it wouldn't be just one color, which in this case is yellow as in samples OP posted.
              • 37628
              Did the new drum start doing the offset immediately or after a few pages? Did you replace drum units only or drum and development units? An over toned development unit can put more toner on the drum than the cleaning blade can handle.
              • mearmi
                • Oct 2010
                • 350
                First thing I did swapping the drums. Fuser is in good condition. Replaced all the original drums.
                thanks
                • jacobchentw
                  • Aug 2021
                  • 2
                  大家好,
                  正在獲取重複圖像。更換了所有感光鼓和轉印帶單元。
                  請查收附件並給予建議
                  非常感謝
                  Flatcable OR PH
