developer leaking on the ADU
  • zubinn
    • Sep 2017
    • 49
    i just did a developer change for BLACK a few weeks ago, every time i print i see a small pile of black developer on the adu.
    so far i just been vacumming it up and continuing with the printing, i forsee some bigger issue from this may arise down the road.
    What is causing this developer leak ? do i need to change a developer tank ? or waste is not draining down the end of the developer tank.
    Any suggestions ?
    z
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: developer leaking on the ADU
    any particular model?
    • zubinn
      • Sep 2017
      • 49
      km c7000
      • Synthohol
        • 5849
        have you inspected the waste tubes?
        is the DV unit over 900k?
        did you open the shutter while vacuuming out the old DV?
        sorry, its hard to help diagnose blindly.
        • zubinn
          • Sep 2017
          • 49
          no dv unit is not over 900k
          i found an interesting issue maybe our machine has a wonky frame, My colleague saw an error message to tighten the upper screw to the imaging engine while we never secured that screw for more than 10 years, we only ever secured the middle screw
          Surprise, not securing the upper screw and just going back to the middle screw solved the developer leak.
          maybe the door to our machine is wonky
          • Ziggy
            • Feb 2018
            • 780
            Which screws are you referring to?
            • Synthohol
              • 5849
              i think they mean the process carriage.
