service / tech rep mode not accessible
  • clubsys1
    • Aug 2025
    recently replaced the drum and developer and cannot access service mode for bizhub 350. The machine instantly defaults to code c2557 and will not on re-boot open to service mode.
    any suggestions?
  • deep
    • Jun 2008
    • 208
    You should carry out F8 right away after machine being turn on.
    Kenny
    • AZ Copier
      Have you tied getting to service mode through trouble reset?
      • clubsys1
        i have tried holding utility button down and power on and still no reset option...just error code.
        How can i or why can't i get directly to F8 before error?
        • Juggy
          Technical Support
          • Sep 2007
          • 101
          hi do warm boot when you get the konica minolta logo with a dot in centre left side press 3 then enter "00000000" enter reset mode. when you are in this mode enter stop,0,0,stop,0,1. then you can run F8 then rest the counters for drum & Developer counter. good luck.
          • clubsys1
            I tried to do this earlier...when i boot the machine and get to the konica logo and press 3, nothing happens. i just end up at the same error code.
            what am i missing?
            • 3angle
              • Kmdurrin
                Copy/Print/Network Tech
                • Dec 2008
                • 132
                You may want to try a new drum and developer.
                Per SSD bulletin #TAUS0655275EN
                SOLUTION: Replace both the drum unit and developer at the same time. Once the code occurs, developer must be replaced to properly recover.
                The correct procedure for replacing the drum is as follows:
                1. Select Tech. Rep. Mode => Counter => Special Parts Counter => PC Life.
                2. Press the Clear Key to clear the counter value.
                3. Turn OFF the main power switch.
                4. Open the Right Door.
                5. Remove the IU.
                6. Remove four screws (silver) and disassemble the Photo Conductor Unit and the Developing Unit.
                7. Replace the Photo Conductor Unit.
                8. Remove three screws and the Developer Scattering Prevention Plate.
                9. Remove the Toner Supply Port.
                10. Remove the Developer.
                11. Set the developer while rotating the gear in the direction of the arrow.
                12. Reinstall the Toner Supply Port.
                13. Using three screws, secure the Developer Scattering Prevention Plate.
                14. Install the four screws to secure the Photo Conductor Unit and Developing Unit.
                15. Install the IU in the copier.
                16. Turn ON the main power switch.
                17. Select Tech. Rep. Mode => Function => F8 and press the Start Key.
                Notes :
                a. After replacing the developer, be sure to execute F8 under Function of Tech. Rep. Mode.
                b. When the main power switch is turned ON, execute F8 quickly.
                Parts: Its what your copier craves!
                • clubsys1
                  tried the reset...didn't work.
                  Why can i not access tech rep mode from the menu? better yet, how do i simply get to tech rep mode to reset the counters because i'm not doing this right.
                  thanks
                  • pepper38_cnd
                    Field Service Manager
                    • Aug 2005
                    • 1075
                    Turn the machine on with the right side door open, enter tech rep mode and go to F8, close door when the start indicator changes color press to start the F8.
                    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                    Now into Ip TV KODI Boxes
                    • pepper38_cnd
                      • Aug 2005
                      • 1075
                      Oops I didn't see that you had not reset the counters. Do as above mentioned turn machine on with side door open, access tech rep mode and reset counters. Turn machine off then on still with side door open access tech rep mode and go to F8 close side door and when the start indicator changes color press to start F8, when F8 completes recycle power.
                      • Hansoon
                        • Sep 2007
                        • 3391
                        5. Remove the IU.
                        Notes :
                        The bulletin left out to cover both collars (Drum Spacers) during the starter exchange procedure. This to avoid starter spilling onto it. Starter messing the collars seems to be the the main cause of ripping the rear mag roller seal causing early drum damage.
                        Hans
                        โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
                        • clubsys1
                          tried this yesterday, per the service manual. when i turn the machine on with the right door open, it boots to the close door indicated by arrow screen...no options are ever presented and keys do not respond. if i close the doors, it goes right to the error.
                          i tried a new drum and developer this morning, but same result. still cannot access tech rep mode.
                          • pepper38_cnd
                            • Aug 2005
                            • 1075
                            The side door does not prevent you from entering tech rep mode. You must have another problem possibly a stuck button.
                            • pepper38_cnd
                              • Aug 2005
                              • 1075
                              The trouble reset is not done by holding the Utility key. On these machines it is done by pressing the button next to the flash card slot.
