recently replaced the drum and developer and cannot access service mode for bizhub 350. The machine instantly defaults to code c2557 and will not on re-boot open to service mode.
hi do warm boot when you get the konica minolta logo with a dot in centre left side press 3 then enter "00000000" enter reset mode. when you are in this mode enter stop,0,0,stop,0,1. then you can run F8 then rest the counters for drum & Developer counter. good luck.
Per SSD bulletin #TAUS0655275EN
SOLUTION: Replace both the drum unit and developer at the same time. Once the code occurs, developer must be replaced to properly recover.
The correct procedure for replacing the drum is as follows:
1. Select Tech. Rep. Mode => Counter => Special Parts Counter => PC Life.
2. Press the Clear Key to clear the counter value.
3. Turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU.
6. Remove four screws (silver) and disassemble the Photo Conductor Unit and the Developing Unit.
7. Replace the Photo Conductor Unit.
8. Remove three screws and the Developer Scattering Prevention Plate.
9. Remove the Toner Supply Port.
10. Remove the Developer.
11. Set the developer while rotating the gear in the direction of the arrow.
12. Reinstall the Toner Supply Port.
13. Using three screws, secure the Developer Scattering Prevention Plate.
14. Install the four screws to secure the Photo Conductor Unit and Developing Unit.
15. Install the IU in the copier.
16. Turn ON the main power switch.
17. Select Tech. Rep. Mode => Function => F8 and press the Start Key.
Notes :
a. After replacing the developer, be sure to execute F8 under Function of Tech. Rep. Mode.
b. When the main power switch is turned ON, execute F8 quickly.
Why can i not access tech rep mode from the menu? better yet, how do i simply get to tech rep mode to reset the counters because i'm not doing this right.
Turn the machine on with the right side door open, enter tech rep mode and go to F8, close door when the start indicator changes color press to start the F8.
Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers. Now into Ip TV KODI Boxes
Oops I didn't see that you had not reset the counters. Do as above mentioned turn machine on with side door open, access tech rep mode and reset counters. Turn machine off then on still with side door open access tech rep mode and go to F8 close side door and when the start indicator changes color press to start F8, when F8 completes recycle power.
5. Remove the IU.
Notes :
The bulletin left out to cover both collars (Drum Spacers) during the starter exchange procedure. This to avoid starter spilling onto it. Starter messing the collars seems to be the the main cause of ripping the rear mag roller seal causing early drum damage.
tried this yesterday, per the service manual. when i turn the machine on with the right door open, it boots to the close door indicated by arrow screen...no options are ever presented and keys do not respond. if i close the doors, it goes right to the error.
i tried a new drum and developer this morning, but same result. still cannot access tech rep mode.
