c6500 error c-4850
  • mr.propper
    • Sep 2009
    • 16
    c6500 error c-4850
    Hallo,
    Symptoms:
    • Engine switch on, -> warming up, -> ready to print appears
    • all testpatterns and listprints are possible without errors
    If disable the Harddisk with software switch 02-01 -0 then I have the following situation:
    • print is possible
    • copy is possible
    • OACB
    • IMCB
    • IPB
    • PRCB
    • IFB
    • 4 x HDD (Harddisk)
    In hope of solution
    Greets mr.propper
  • Si@danwood
    • Mar 2008
    • 154
    Wasnt this a firmware issue?What level of firmware are you running..also what version of system software is the Fiery running?...Si
    • mr.propper
      • Sep 2009
      • 16
      I have checked with firmware vers.40, 50 and 60.
      The fiery runs with 2.0
      This problem c-4850 also appears without Fiery.
      • Si@danwood
        • Mar 2008
        • 154
        this is a very early pdf but has a few entries relating to 4850
        i am aware that the firmware you are running is way past these just for your information more than anything else
        • mr.propper
          • Sep 2009
          • 16
          Hallo,
          i have solved this problem.
          The engine has self change the HDD to "faulty part isolation" with software-switch 18 bit 7 to 1.
          After HDD-aktivation with SW-switch 2-0 to 1 and 18-7 to 0 appears error C-D0E1.
          I replaced the HDD/K and i carry out "Replacement of the Hardisk" from service-manual and that was fine.
          Lucky greetings
          mr.propper
          • kmcopier
            PSP
            • 183
            there is special firmware for fixing the HDD error and was solved in mass production firmware
            • jma676
              Expert Tech
              • Mar 2009
              • 323
              Solution ID TAUS0801834EN* Solution Usage 6
              Description
              Error code C-4850 (C4850).
              Solution
              PROBABLE CAUSES:
              1. Firmware update required.
              Please update to firmware version 40 or greater. The latest version of firmware, system software or print drivers is available via the Konica Minolta Download
              Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
              Note : If the problem occurs while using the SD-501, install mimimum version 30-GCD for the Saddle Stitcher. A C-4840 (C4840) code may also be
              indicated.
              2. The Overall Control Board has failed.
              Replace the OACB (p/n A03UH0105A).
              IMPORTANT : Firmware should be updated to version 40 before replacement of the OACB.
              3. Incorrect initial settings. Perform the following:
              a. Depress "Utility"
              b. Select "User setting"
              c. Select "Initial setting"
              d. Select "Copy Initial Setting"
              e. Select "ADF" or select "1 -> 1" on initial copy mode
              f. Press "OK"
              Note :This is a firmware bug that will be corrected a future release of firmware (above version 41).
              SPECIAL NOTE : Solution contribution by Clinton Marquardt, ESS/BSE and Chuck Tripp, Production Print/SSD
              • jma676
                Expert Tech
                • Mar 2009
                • 323
                Solution ID TAUS0900559EN* Solution Usage
                Description
                Error code SC-4850 after power ON and warm up hasfinished.
                Solution
                CAUSE: If a modem is connected to the device and
                no CSRC configuration has been done -ORa
                RAM clear has been executed on the device.
                SOLUTION: To correct:
                Set the CSRC configuration and perform an initial connection of the device -ORdisconnect
                the modem from the device properly if no CSRC connection is needed.
                SPECIAL NOTE : Solution contribution by KM Europe (BEU) - CSRC Team.
                • jma676
                  Expert Tech
                  • Mar 2009
                  • 323
                  Field Service Ver.2.0 Mar 2009
                  Troubleshooting.
                  SC-C4850 = Overall Control Software Accessed an invalid address. (OACB).
