konica 7165 error 1 w/ new developer
  • W242
    • Aug 2009
    • 43
    I have a konica 7165 I changed the developer because of background (had over 500k) Installed new Developer and went thru set up. when I got to the Auto dot diameter adjustment I get an error 1 code. I cleaned the TSCB with no change. Help, I need to get this machine going. What else can be causing this? Did I not Do something that needs to be done in the set up?
    Thank you for any help.
  • freefall
    How old is the drum? Are there any visible wear lines on it? If there are then it is a good bet you will need to replace the drum also. Lines can be caused by normal wear or the occasional drum wrap that wasn't taken care of immediately.
    • mascan42
      • Oct 2008
      • 485
      This. I know the PM schedule says the drum should last 500k, but I've never seen it make it that long. I always change it at the same time as the developer & PM kit.
      • hachetman
        • Jul 2009
        • 96
        aman to changing the drum with the developer install all the pm parts that come with the pm kit wire cleaners and all
        Steve Baker
        hachet1_12@outlook.com
        • mrwho
          Major Asshole!
          • 4299
          If you just changed the developer and didn't do the complete PM, try to clean the charge corona (or to replace the wire and the grid). That could be your problem.
          Mascan42
          Ibid
          • W242
            • Aug 2009
            • 43
            ok, I just installed the complete PM kit and new P/R drum. I'm still getting the error 1 with the Auto dot diameter adjustment. any other suggestions?
            • mrwho
              Major Asshole!
              • 4299
              Dumb question, but did you start the adjustments from the beginning or did you just resumed from where you were?
              Also, when you print the LD1 and LD2 adjustment charts, do the charts come out nice or are they washed out?
              Mascan42
              Ibid
              • ebm
                • Apr 2007
                • 183
                First, I have been able to run the machine even if Drum peculiarity adjustments showed an error. Are you not able to make any copies/prints at all?
                Second, have you tried to check if you are getting any signal from the TCSB in the 47-mode? You posted that you cleaned, but maybe sensor failed or not connected good.
                • Albonline
                  • Sep 2008
                  • 1153
                  agreed, the tcsb has been known to blow up just by looking at it funny.
                  • W242
                    • Aug 2009
                    • 43
                    I'm able to run a copy just fine, looks great at this point. In the 47 mode, I'm assuming it is 008, is reading 0 (6 is 139 and 7 is 255) the 7272 next to it reads 246 at # 8. So I'm guessing the TCSB is bad?.
                    • W242
                      • Aug 2009
                      • 43
                      Is the TSCB called the toner controll assembly in the parts book 56AA-9102E?
                      The best price I've found is 199.60 at western multigrahics, is there a better or cheaper alternative?
                      • ebm
                        • Apr 2007
                        • 183
                        Konica dealer price (04/09 price list) = $138.48. Good for 7155/65, 7255/72, Bizhub 600/750/601/751, Di-551/650/7210, Force 65.
                        • Albonline
                          • Sep 2008
                          • 1153
                          if you have another copier close why not confirm that the part is bad by swaping between units? before you spend any money?
