I have a konica 7165 I changed the developer because of background (had over 500k) Installed new Developer and went thru set up. when I got to the Auto dot diameter adjustment I get an error 1 code. I cleaned the TSCB with no change. Help, I need to get this machine going. What else can be causing this? Did I not Do something that needs to be done in the set up?
Thank you for any help.
