konica minolta c252 code c5102
  • brent
    • Nov 2008
    • 1214
    so the book says make sure the connector is connected on the main motor. then replace in order pwb m then pu 1. well in real life I don't have these parts in stock. so has anyone had this problem and does the pwb m usually take care of the problem? fuses? I did not have time to take the machine apart today. I am doing research on this.
    any ideas?
    thanks very much.. brent
  • ebm
    • Apr 2007
    • 183
    Main Motor drives Imaging Units, Transfer Belt, etc. Check to see if Main Motor drive is binding before start to replace boards and such.
    • brent
      • Nov 2008
      • 1214
      I see that minolta has a bulletin on this. seems like the motor that drives those units goes out. I should have spent more time today on it. there was a jam in the machine. it is just probably just still jammed... I am going back in a couple days to check it out again.
      thanks
      brent
      • JSC
        Gimp
        • Dec 2006
        • 618
        Every time i have had this code ( about 5 times ) it has always been the motor.................
        The gene pool could use a little chlorine.
        • kmcopier
          PSP
          • Oct 2008
          • 183
          jou check it by swapping it with the motor fro the color one make a color copy and you have a error on the color motor it's known problem
          • brent
            • Nov 2008
            • 1214
            sounds good to me. I got to read up in the service manual. are these motors hard to swap out?
            thanks
            brent
            • kmcopier
              PSP
              • Oct 2008
              • 183
              no only you have tp remove the unit with the mfp board's ,hdd in it. it's good discripted in the manual if you have any change take a motor with you saves a lot time
              • brent
                • Nov 2008
                • 1214
                I found it on page 143 in the manual. I am going to order a motor to take with me.. hopefully that is it rather than going into the pwb m or pu1. ya know?
                thanks for your imput
                brent
                  • 30293
                  c5102
                  can you post the service bulletin from konica on this?
                  • gerryhuerta
                    AccService
                    • Jul 2009
                    • 198
                    Yup. Defenite MOTOR.
                    • Having a ball
                      • 17
                      any ideas?
                      It is the motor on these models no dought about it.
                      • hobietacker
                        • 7
                        KM 252 C5102 code
                        I replaced the M1 motor and the blk IU the machine started up but there was a god awful vibration. Then it threw the C5102 code again and now it will not work again. I am removing everything again and go deeper into the problem. I will be back with the solution. Stay Tuned.
                        • mrwho
                          Major Asshole!
                          • 4299
                          Still tuned. What turned out to be the problem?
                          Cheers!
                          Mascan42
                          Ibid
                          • copytechman
                            • Nov 2008
                            • 947
                            Ouch! I've had a couple o' these, and it's always been the motor (so far)!
                            Regards!
                            A.
                            • Stirton.M
                              All things Konica Minolta
                              • Oct 2009
                              • 1804
                              Sometimes this issue can be generated from a binding image unit. Sometimes simply shaking the IU from end to end is enough to loosen up the developer. It's certainly worth the time it takes relative to what is in store with replacing the motor. At my office, this issue is believed to be the catalyst for burning out the driver chips for the motor itself.
                              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                              ---Groucho Marx
                              Please do not PM me for questions related to Konica Minolta hardware.
                              I will not answer requests or questions there.
                              Please ask in the KM forum for the benefit of others to see the question and give their input.
