Konica 7045
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    Konica 7045
    Hi all,
    I am working on a Konica 7045. The customer has complained of intermittent jamming for a year. Finally, I am the one that gets to observe the E89-02 code that stops the machine. The previous techs did not observe this code and it never shows as a jam and no one noticed....nevermind.
    The code only appears on long 8 1/2 x 11R, 14 " and 11x17 and only when duplexed 2 - 1 or 2 - 2. After the last "good" copy the next is totally missing side one, side two is fine. There is a good side one on the way to getting side two at the registration of the ADU and a side one that is shifted toward the lead edge, missing a good two inches. This is partially sticking out of the fuser. After the machine stops and before the code appears, the paper drive stops and the developer motor, main motor and fuser continue to spin.
    I have replaced the Control board (no extra memory) and the ICB to no avail. I have a ADU board, FNS board, and ADF board and a Scanner board on order. Prior techs have replaced and/or cleaned clutches and gears from paper feed to exit.
    Nice to start off w/ a good one. eh?
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    No takers?
    • bushy
      • 34
      just a long shot but the door switches play havoc with these 7033,7040,7045 m/cs
      I had one this morning (ausie time) that just ran on and said m/c copying but nothing was comming out.
      turns out the door switch mount had brocken so the switch was only 1/2 making.
      I repaired the brocken mount and replaced the door switch and all ok now
      I pulled the old switch apart and the contacts were completely burnt out.
      I have replaced 1 dozen or so of these little devils in the last 12 months for various reasons maybe this is another one.
      I dont know if this has any bearing on your fault but it sounds like you have nothing to lose by replacing the switch
      bushy
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        bushy
        Thanks for the reply.
        The door switch has been replaced with no results. I really thought that that was the problem.
        • skirt_chaser
          Firmware ?
          My book says "abnormal control board communication". I would look at flashing the board with the latest ROM version if you have replaced the board already. Just my two cents....
          • blackthumb
            This may be a ground problem. The drum ground, board ground or the wall may be an issue here. Since the paper is jammed during process, and there are both registration and image problems, and the code is for board communication, these areas are the places I would look.
            • ebm
              • Apr 2007
              • 183
              Konica SSD knowledge base has quite a few "E89-02" solutions. You should check it out.
              • RockETop
                Curmudgeon at large
                • Apr 2007
                • 171
                Control board has been flashed and replaced and flashed. No soap. Thanks!
                • RockETop
                  Curmudgeon at large
                  • Apr 2007
                  • 171
                  I have, but they do not list symptoms. I have the RADF board and the FNS board to try from solutions.
                  • RockETop
                    Curmudgeon at large
                    • Apr 2007
                    • 171
                    Great idea! I also have a memory parameter board to try too, or "meter memory board."
                    • nightshade
                      Chromographic Supremesist
                      • 158
                      NVRAM
                      • ebm
                        • Apr 2007
                        • 183
                        One of Konica's solutions mentioned the version compatability. When you flashed, did you do all boards (including finisher) or just the printer control?
                        • ebm
                          • Apr 2007
                          • 183
                          • RockETop
                            Curmudgeon at large
                            • Apr 2007
                            • 171
                            Yep.
                            • RockETop
                              Curmudgeon at large
                              • Apr 2007
                              • 171
                              The answer is...
                              Memory Parameter board. The machine started responding more quickly to keystrokes too.
                              Thanks for the replies.
                              RET
